Previewing Gray Gain Changes
2006-12-03 by stasunas
HELP!! I must be getting old but I can't preview the changes I make to
a custom dot gain curve. I start with a 21 step grayscale and apply one
on Paul's curves. I then print the curve. I then go into CS2 and
through assign profile I check don't color manage. I then go into Color
Settings and in Working Space Gray I select Custom Dot Gain. The Curve
comes up but as I make changes it has no effect of the grayscale on the
monitor. I have Preview checked in the Color Setting menu. I have tried
flattening the scale and the curve, converted from RGB to Grayscale,
making the background active - - - still no effect. I have done this
before but for some reason I continue to have difficulty with this.
Thanks in advance.
