Canon iPF 5000 Printer
2006-12-06 by scott_now_coming
"I also continue to be impressed with the Canon's monochrome printing.
Dead neutral, and lovely tonalities. I see no need for a dedicated
monochrome printer any longer, and the 16 bit driver offers versatile
toning capabilities. "
That quote is from Michael H. Reichmann on his web-site:
http://www.luminous-landscape.com/
Anyone seen a monochrome print from this Canon printer? Care to comment?
Scot
Re: [Digital BW] Canon iPF 5000 Printer
2006-12-06 by Tom Baker
Why would the 16 bit driver make a difference?
  Tom Baker
Scot
2006-12-06 by CDTobie@aol.com
In a message dated 12/5/06 9:51:11 PM, scott_now_coming@... writes:
Sure, I have the machine right here... I don't see any significant
differences between its built-in B&W and Epson's (on which I suspect it was modeled). In
either case I still want Photoshop softproof capability, tighter control of
neutrality and linearity, and more abilities to tint and tone as desired. So I
do   use this printer for a fair amount of my B&W, but not in its built-in B&W
mode.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
In a message dated 12/5/06 10:11:38 PM, tbaker1328@... writes:
Its a bit easier to print from, if you use Photoshop. And its particular bugs
and issues are different, but I don't see significantly different results,
once I have both the driver and the export module working properly, through
profiles built for each. But, Iike you, I don't see why it would make B&W easier,
as it doen't really have any B&W tools.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
RE: [Digital BW] Canon iPF 5000 Printer
2006-12-06 by Paul Roark
Is there any difference in the Photoshop-to-driver connection or interface
that gives profiling software like PFP any more or less control than what I
can theoretically get with RGB image adjustment curves used in Photoshop?
  _____
Subject: Re: [Digital BW] Canon iPF 5000 Printer
modeled). In
I
mode.
C. David Tobie
Datacolor Inc.
CDTobie@colorvision <mailto:CDTobie%40colorvision.com> .com
www.colorvision.com
In a message dated 12/6/06 3:47:57 PM, paul.roark@... writes:
Well, lets see. There's the media settings, and all other stuff that have to
somehow be accounted for. And the fact that 3d LookUp Tables can't possibly be
emulated with channel curves. But no, its all a matter of sending RGB values
to the printer, though you'd be surpised how often thats not done right, or
optimally.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
2006-12-06 by Roy Harrington
Not really.  It's the same basic thing -- as long as we're talking grayscale
input and RGB output workflow that you've used for a long time.  An RGB to
RGB transformation can be 3 dimensional i.e. the R output can depend on all
3 input RGB channels.
Some details are a little different:
In PS you are limited to number of points (14 isn't it?).
The point values are just 8 bit (0 to 255), but the interpolation is 16-bit
as long as your data is 16 bit.
CMM can have more points and they are 16bit, but the points have to be
evenly spaced.
PS uses nice smooth cubic splines to connect points, CMM uses just simple
linear interpolation.
Roy
> Paul
2006-12-07 by Paul Roark
Roy,
That sounds reasonable.  So, basically, as David says, ".its all a matter of
sending RGB values
to the printer,."  But in addition to this the software can take advantage
of a 16 bit path and also more points on the curves.
What I don't hear, however, is that profiling software can alter the gray
ink substitution algorithms of the driver in printers like the Epons 2400.
That is, for example, as I understand it, the Epson k3 printers in ABW mode
use more gray ink in the mix than in RGB mode, at least for rather neutral
prints.
Has anyone ever quantified this difference?  With, for example, a neutral
file (or slightly warm one), what amounts of each ink are used in the image?
Does the RGB approach use more color ink in the image than ABW?  If so, how
much?
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Roy
Harrington
Sent: Wednesday, December 06, 2006 1:39 PM
evenly spaced.
Roy
I
> Paul
> www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/>
2006-12-07 by CDTobie@aol.com
In a message dated 12/6/06 7:19:15 PM, paul.roark@... writes:
> prints.
I'd heard that as well, but the effect of it I was most concerned about was
metameric shift under differing light sources, and I don't find a significant
variation between AWB and Color prints of similar gray values in terms of
observable metamerism. In fact I find it difficult to distinguish higher metamerism
between either of these, and prints from tinted gray inksets. So my
conclusion is that all of these methods make it under the visible metamerism bar, and
what we have left to deal with is smoothness, detail, and what we see when we
get REALLY close to the prints...
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
