Hahnemuhle Fine Art Pearl & Flaking
2006-12-22 by Terry Ritz
I've just finished cutting up my first set of prints made on Hahnemuhle Fine
Art Pearl (2200 / MIS Pro). On some prints I had flaking on the edges, which
is quite noticable since the background is black. I have a good quality
rotary trimmer and have not had this issue before.
Has anyone noticed this before with FAP?
Terry.
Re: [Digital BW] Hahnemuhle Fine Art Pearl & Flaking
2006-12-22 by will gibson
Terry,
Yes, That happens to me too. I have dry mounted the prints for
exhibition and my work around was to leave a very small edge of white
around the image to hide the flaking. Don't suspect there's a good way
of cutting a black cleanly and having it not be a ragged edge. Just the
nature of the paper.
Will
>Terry.
2006-12-22 by Peter Palmieri
I am not getting good results with FAP. Perhaps it is the media setting that I am using with an Epson 4800? I am using the Premium Luster (250) setting. Which media setting would be recommended for this paper?
Peter
  Sent: Friday, December 22, 2006 10:35 AM
  Subject: Re: [Digital BW] Hahnemuhle Fine Art Pearl & Flaking
  Terry,
  Will
  >Terry.
RE: [Digital BW] Hahnemuhle Fine Art Pearl & Flaking
2006-12-22 by David Whistance
Peter
Hahnemuhle recommend Premium Semi Gloss on their website:
http://www.hahnemuehle.com/media/downloads/62/Print_Instruction_Epson.pdf.
David Whistance
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Peter
Palmieri
  Sent: 22 December 2006 16:19
  Peter
  Terry,
  Will
Fine
which
  >Terry.
Thanks--much appreciated!
Peter
  Peter
  David Whistance
  Peter
  Terry,
  Will
  Fine
  which
  >Terry.
2006-12-23 by Terry Ritz
Thanks for the feedback Will.
I was unsure if it was the ink, paper or (least likely) my cutter. I'm going
to try the same print using Innova F-Type Gloss with the hope that it fares
better. I would prefer not to leave a white border.
Terry.
> good way
> edge. Just the
I found the best balance between DMAX and shadow detail on an Epson 2200
running MIS Pro inks was to use the Premium Glossy setting.
Terry.
> Peter
2006-12-23 by Peter Palmieri
No matter whether I use a custom made profile, Hahnemuhle's profile for FAP or just choosing the 4800's ICM, the prints I am getting still look "muddy". I have used different media settings, including Premium Semi-Gloss (250). Premium Glossy (250) and Premium Luster (250) with the mentioned profiles without success. Too, I have done a power clean thinking that could be a problem. Then I adjusted the paper thickness to .4mm in the Epson's driver. No matter which set of variables I use the prints are still appear "muddy". A first glance gives the impression that the wrong side of the paper was used to make the print. I wish that was the cause.
There is one constant, and that is the paper.
Good thing I didn't buy larger sizes of this paper!
Thanks for your help and happy holidays to all.
Peter
  Sent: Friday, December 22, 2006 11:21 PM
  Subject: RE: [Digital BW] Hahnemuhle Fine Art Pearl & Flaking
  Terry.
  > Peter
2006-12-23 by Michael King
Peter you are not going to get a great dmax on this paper.
Best one can do is about L*7 vs 2.5 for something like Premium Luster.
Its great for images where you don't have / care about deep blacks and where
you want detail held in the highlights.
It really holds detail in the highlights well.
Horses for courses.
Mike
> Peter
> From: Terry Ritz
> To: DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>
> Terry.
> > Peter
