UT-3D inks - something unexpected
2006-12-27 by benc_1972
I've just started playing around with the UT-3D inkset in my Epson 1290
and have made a few PS curves for EEM. In preparation for some QTR
experiments I printed the QTR calibration page, and to my great
surprise the primary toner (magenta and light magenta position) inks
look quite different to each other. Whereas the LM position ink is
distinctly bluish, the M position is much more of a cool gray - it
certainly doesn't look like a continuation of the same shade through
the darker tones, the way the carbon inks do.
I didn't expect this. Has anyone else had the same experience? Is my
assumption correct that the colors in the full-strength and light
positions would look roughly the same? Or did I just not shake the
bottle?  ;-)
Thanks in advance,
Ben Connor
P.S. If anyone else is using, or plans to use, this inkset with this
printer, I'm very happy to share my curves or to try yours. Drop me a
note if you're interested.
BC
RE: [Digital BW] UT-3D inks - something unexpected
2006-12-27 by Paul Roark
Ben,
>... UT-3D inkset in my Epson 1290 ...
>... printed the QTR calibration page, and
> LM position ink is distinctly bluish,
>the M position is much more of a cool gray ...
That's intentional.  The LM is going to be the main toner in the parts of
the image where tone matters most.  The LM contains the usual cyan-blue mix.
However, with most if not all papers, a toner with that mix goes too magenta
in the deep shadows.  So, more cyan is used there.  The M-position toner
also does double duty as a PKN -- neutralized PK.  So, the amount of toner
to carbon is also considerably less than with the LM, but it should have
enough there to handle the shadow tones.
Good luck with the system.
Re: UT-3D inks - something unexpected
<paul.roark@...> wrote:
> Ben,
parts of
blue mix.
too magenta
toner
of toner
have
> Paul
> www.PaulRoark.com
Thanks Paul - and thanks for formulating these inks. I'm having heaps
of fun and have some nice results so far.
