"The Lab values are not in order..." error
2007-01-01 by guy_staley
Using the Create ICC program, I'm getting this error, even though I can see no problems
with my data.
Here's the input text file:
Gray	Lab_L
0	95
5	89
10	85
15	81
20	77
25	74
30	70.5
35	67
40	65
45	62
50	59
55	56
60	54
65	51
70	47
75	44
80	40
85	37
90	30
95	23
100	14
And here's the output text file:
QTR-Create-ICC version 2.4.2.0
File: /Users/guystaley/Desktop/2200_EEM_MHW_Test1-out.txt
Step	Dens	Lab	A	B
0.00	0.000	0.00	0.00	0.00	L                             b                             +
25.00	0.000	0.00	0.00	0.00	L                             b                             +
50.00	0.000	0.00	0.00	0.00	L                             b                             +
75.00	0.000	0.00	0.00	0.00	L                             b                             +
100.00	0.000	0.00	0.00	0.00	L                             b                             +
Cannot make a profile.
This is my first time using this program, and I'm following Paul Roarke's method.
Any suggestions???
Re: [Digital BW] "The Lab values are not in order..." error
2007-01-01 by Tom Baker
I only see on decimal point in you list.  If that's the case, these aren't valid LAB values.  And, the last on 10014 can't be a valid value.  What are you reading you test strips with?
with my data.
Gray Lab_L
0 95
5 89
10 85
15 81
20 77
25 74
30 70.5
35 67
40 65
45 62
50 59
55 56
60 54
65 51
70 47
75 44
80 40
85 37
90 30
95 23
100 14
Step Dens Lab A B
Any suggestions???
Re: "The Lab values are not in order..." error
2007-01-02 by Jeff Randall
Guy:  I cut and pasted your values into a text file (.txt) and had no
problems creating a profile and output file.  I don't know what to
tell you.  You could download the program again.  Check you data file
for extra spaces at the end of each line and at the end of the data.
Did you use a true text editor like notepad to leave no formatting
behind?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "guy_staley"
can see no problems
> with my data.
> Gray	Lab_L
> 0	95
> 5	89
> 10	85
> 15	81
> 20	77
> 25	74
> 30	70.5
> 35	67
> 40	65
> 45	62
> 50	59
> 55	56
> 60	54
> 65	51
> 70	47
> 75	44
> 80	40
> 85	37
> 90	30
> 95	23
> 100	14
> Step	Dens	Lab	A	B
b                             +
b                             +
b                             +
b                             +
	L                             b                             +
RE: [Digital BW] "The Lab values are not in order..." error
2007-01-02 by Paul Roark
Try separating the columns with tabs.
  _____
guy_staley
Sent: Monday, January 01, 2007 3:06 PM
Subject: [Digital BW] "The Lab values are not in order..." error
no problems
with my data.
Gray Lab_L
0 95
5 89
10 85
15 81
20 77
25 74
30 70.5
35 67
40 65
45 62
50 59
55 56
60 54
65 51
70 47
75 44
80 40
85 37
90 30
95 23
100 14
Step Dens Lab A B
method.
Any suggestions???
2007-01-02 by guy_staley
The values were originally formatted per your instructions, Paul. The formatting gets all
funny when I copy and past into my post.
Let me try again without copying and pasting.
I created two columns, seperated by tabs, like this:
Gray     Lab_L
0         95
5         89
10        85
15        81
20        77
25        74
30        70.5
35        67
40        65
45        62
50        59
55        56
60        54
65        51
70        47
75        44
80        40
85        37
90        30
95        23
100       14
Hope that comes across properly in the post.
Some particulars: I'm using QTR-Create-ICC version 2.4.2.0 running on a Mac in OSX
10.4.8. I'm creating the text file in Text Edit as an RTF file.
It's odd that Jeff had no issues when he copied my data into a new test file. Could it be that
my file is an RTF file as opposed to a .txt file???
Thanks to all for the support!
-Guy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...>
> Paul
>   _____
> guy_staley
> no problems
> with my data.
> Gray Lab_L
> 0 95
> 5 89
> 10 85
> 15 81
> 20 77
> 25 74
> 30 70.5
> 35 67
> 40 65
> 45 62
> 50 59
> 55 56
> 60 54
> 65 51
> 70 47
> 75 44
> 80 40
> 85 37
> 90 30
> 95 23
> 100 14
> Step Dens Lab A B
> method.
> Any suggestions???
Make it a text file instead of RTF.  That could be it.
  _____
guy_staley
Sent: Monday, January 01, 2007 6:08 PM
Subject: Re: [Digital BW] "The Lab values are not in order..." error
formatting gets all
Gray Lab_L
0 95
5 89
10 85
15 81
20 77
25 74
30 70.5
35 67
40 65
45 62
50 59
55 56
60 54
65 51
70 47
75 44
80 40
85 37
90 30
95 23
100 14
in OSX
-Guy
> Paul
> www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/>
> _____
> guy_staley
see
> no problems
> with my data.
> Gray Lab_L
> 0 95
> 5 89
> 10 85
> 15 81
> 20 77
> 25 74
> 30 70.5
> 35 67
> 40 65
> 45 62
> 50 59
> 55 56
> 60 54
> 65 51
> 70 47
> 75 44
> 80 40
> 85 37
> 90 30
> 95 23
> 100 14
> Step Dens Lab A B
> method.
> Any suggestions???
That was the problem. Saved as a regular .txt file and all is well; or at least the Create-ICC
program is outputing a curve.
Problem now is that when I actually use the curve, my step wedge is completely blocked
up from about 70% on down.
I'm trying to get a handle on this, but I'm having a hard time so far using UT-3D inkset on
a 2200 with CS2. The step wedge with NO curve applied is much better.
I'm going to start again and see if I can improve things.
-Guy
> Paul
>   _____
> guy_staley
> formatting gets all
> Gray Lab_L
> 0 95
> 5 89
> 10 85
> 15 81
> 20 77
> 25 74
> 30 70.5
> 35 67
> 40 65
> 45 62
> 50 59
> 55 56
> 60 54
> 65 51
> 70 47
> 75 44
> 80 40
> 85 37
> 90 30
> 95 23
> 100 14
> in OSX
> -Guy
> eThePrint@yahoogroups.com, "Paul Roark" <paul.roark@>
> > Paul
> > _____
> > guy_staley
> see
> > no problems
> > with my data.
> > Gray Lab_L
> > 0 95
> > 5 89
> > 10 85
> > 15 81
> > 20 77
> > 25 74
> > 30 70.5
> > 35 67
> > 40 65
> > 45 62
> > 50 59
> > 55 56
> > 60 54
> > 65 51
> > 70 47
> > 75 44
> > 80 40
> > 85 37
> > 90 30
> > 95 23
> > 100 14
> > Step Dens Lab A B
> > method.
> > Any suggestions???
