So how "micro" IS micro-banding?
2007-01-04 by guy_staley
I'm finally getting good prints using UT-3D on an SP2200 with Musie Silver Rag and Paul
Roark's profiles. And to the un-aided eye, the prints look very good. But upon examination
with a lupe, I'm seeing micro-banding (mostly in the mid-tones). Once again, I can only
detect this banding when examining the prints with a lupe.
Is this normal inkjet behavior, or is it possible to acheive zero banding, even when
scrutinizing under a lupe?
Thanks.
-Guy
RE: [Digital BW] So how "micro" IS micro-banding?
2007-01-04 by Paul Roark
Assuming the nozzle check is perfect, alignment of the print head would be
the next thing to try.  Even after you've done all you can, however, a fair
percentage of printers still show some microbanding when a loupe is used to
examine the prints.  Most are not perfect.
  _____
guy_staley
Sent: Thursday, January 04, 2007 12:21 AM
Subject: [Digital BW] So how "micro" IS micro-banding?
Rag and Paul
upon examination
I can only
even when
Thanks.
-Guy
Re: [Digital BW] So how "micro" IS micro-banding?
2007-01-04 by Bob Frost
I used to get microbanding to various degrees when I used 1440dpi resolution
or below on various Epsons. It could be minimised, as you suggest, by head
alignments (even though I wasn't using high-speed printing), but it usually
disappeared entirely if I used 2440 dpi resolution or above. I think this is
because at the highest resolutions, the printer overlaps the bands of ink
much more - 'super microweave' or something similar - and this hides the
micro-variation in paper and head movements. The downside is that printing
is slower, but 'perfection doesn't come easily' as they say.
Bob Frost.
Sent: Thursday, January 04, 2007 4:39 PM
Subject: RE: [Digital BW] So how "micro" IS micro-banding?
Actually, this micro banding is occuring in super photo 2880 print resolution mode,
micro-weave on. Also, this micro banding wasn't apparent on matt papers, only since I've
started using the Crane Silver Rag paper.
I guess I'll try aligning the heads; although I did this not too long ago.
-Guy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Frost" <bob@...> wrote:
> Bob Frost.
> From: "Paul Roark" <paul.roark@...>
2007-01-05 by Steven Karafyllakis
I've been finding the hard way that there are 'degrees' of
perfection; simply having all the little lines present is not
enough. The lines need to be clean & straight, with no
little 'hooks', otherwise you may still get banding. In this case
more agressive cleaning might help, such as wiping the head with
windex impregnated cloth strips.
As you say, though, many printers don't get perfectly clean-though
I'm happy to report my 3800 is prefect in that regard. Not a hint of
microbanding! Finally!
Steve Karafyllakis
would be
however, a fair
is used to
> Paul
>   _____
> guy_staley
Musie Silver
> Rag and Paul
good. But
> upon examination
Once again,
> I can only
banding,
> even when
> Thanks.
> -Guy
