Problem with cleaning cycles in Epson 2200
2007-01-23 by Sergei Antonov
Hello all, After years of work without any significant problems my printer got a serious clog. It was loaded by MIS UT7 inkset, when I discovered that I lost two nozzles (Cyan and Light Cyan) in the middle of page. Before that printout nozzle pattern was perfect. I didn't get nozzles back after number of cleaning cycles, then treating with Windex on the rest pad, then after loading two carts with MIS Fluid and doing cleaning cycles with it... I see some traces of clean liquid when I print purge pattern with cleaning fluid, but when I change back to ink, both nozzles are still clogged. Worst thing is that after cleaning cycles my other nozzles are going bad too. Questions: is it possible that this part of pump that is doing suction is too dirty and makes things worse during cleaning cycle? If it is, could I clean it somehow? Is it possible to disassemble the thing and do a good cleaning of this pump? Is it possible that UT7 Cyan and Light Cyan turned bad after 2.5 years in the bottle? Thanks in advance, Sergei
