I just start doing some paper tests last weekend after not using my
2400 for over 6 months. I did a quick nozzle check and, after two
nozzle cleanings, I was good to go for printing.
I was very surprised that that was all it took to be able to print
again. I am using K3 ink.
keith
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Linda Jacobs"
<lajacobs@...> wrote:
> I don't see how your printer would get damaged from non-use but you
> might have some dried ink clogging the nozzles.
> I would start by running a nozzle check then up to 3 cleanings if
> necessary. If you are still clogged then let the printer sit for awhle
> (at least a few hours) and run another nozzle check.
> In the future, run a nozzle check every 4 or 5 days during periods of
> non-use. Doesn't take much ink and well worth it to keep the printer
> happy.
> Good luck,
> Linda
> On 1/25/07, FRD <f.dz@...> wrote:
> > Hey group,
> > I've been so busy lately that I haven't been able to attend to my
> > photography. But I've got a huge project coming up this weekend
and need to
> > print from my Epson.
> > It's probably been over three months since my last print and I'm
afraid of
> > damaging the heads (how likely is it that buildup can do this?)
and am not
> > sure what sort of pre-print procedure can best mitigate any
problems...
> > I am printing both B&W and color and using stock K3 inks.
