On Behalf Of markebrauer:
>... have very good Photoshop skills.
Image editing is a big part of why I'm using digital output. It's
interesting how many different types of workflows can accomplish the same
thing in PS.
> ... dedicated B&W carbon inksets sound promising for excellent quality.
For a given level of technology, the dedicated B&W systems can usually get
something more out of the printer by sacrificing full color. With the 2400,
the number of inks has reached the point where still very good B&W can be
had from the standard color ink arrangement. In large format the 3800
finally has enough to do both matte and glossy with full color also. I
would not want to be limited to just one type of paper.
Third party inks, whether B&W or color, can save you a lot of money.
In terms of fade resistance, the MIS and Cone B&W pigments are the best I've
tested and usually beat the Epson OEM inkset in my fade tests. (The only
potentially significant fade test I've seen where MIS and Cone current
generation of inks did not beat Epson OEM inks was with respect to the
magenta pigment. I now use Epson LM in the non-blended inksets like the
4K+cm approach. But that is not where a person just starting digital B&W
should start.)
> ... The printer will be dedicated to B&W from day one, no color.
>- I want to keep costs down so letter size seems to make the most sense.
C88 or 220 (The 220 is now discontinued; however, the 340 works the same and
is still available.)
>- I want the system I choose to be controllable,
> so I can eventually learn much (everything?) about printing.
The C88 is the easiest and cheapest.
On the other hand, a basic hextone ink arrangement like with the 220/340 has
a longer learning curve that can take you to the top of the B&W printing
workflows.
(If and when the 260 and 1440 have good third party carts and chips readily
available, the 260 will be probably be the starting place.)
For one step up, to 13" paper, I like the 2200. A good refurbished unit can
be an excellent buy.
>- I'd like a relatively recent printer as I expect to move
> to Vista soon ...
I don't know what problems might come up. On the PC side, I have had
reasonable luck with support for Epson printers as long as I've need doing
this. But, I would hesitate to go back further than the Epson 2200.
>- Refillable ink cartridges are appealing. CIS may be in the future.
The CIS is nice if you do a lot of printing with the same inkset. I
experiment with too much to make it work for me. (Note that a CIS may have
the same problems as the large format printers if they are not used. See
http://home1.gte.net/res09aij/4K+.pdf at page 4. The best cure is an
auto-print system as sold by MIS at http://www.inksupply.com/cobra.cfm#ap )
>The MIS UT-EZ for the Epson C8X line looks appealing
It's easy and economical.
>but it's not clear if it allows for real control once you get
>beyond the "EZ" stage.
It has a shorter growth path than the 220/340 hextone and 2200 k2 (close to
a hextone) have.
> Also, does it actually work properly in the latest C88/C88+ models.
They seem to be very close.
I think you'll have a good chance of getting a good print quickly.
Above that, you'll often be better off if you can use QTR "Create ICC" to
make custom profiles. You can even make these with just a flatbed scanner
and the QTR program. See http://home1.gte.net/res09aij/Making_B-W_ICCs.htm
Of course, you'll want to be able to get positive feedback from the system
without having to learn any more software. I think the C88+ should be able
to do that for you.
>The Epson R200/220 with MIS inks seems to definitely be controllable
Yes.
>but will these printers be supported in the future (Vista)?
I don't know, but I expect they will be.
> The more recent R260 evidently uses different carts.
Yes. It's too soon to buy it for B&W.
>If the C88 is feasible, what's the difference in the "+" model.
In terms of apparent printing characteristics with Win XP, almost none from
what I can tell.
> The 88+ is listed at Microsoft as Vista compatible (with no driver yet).
That might be worth something.
Hope this helps.
