less micro-banding on 4000? Please??
2007-02-15 by sagaface
Hi All....
I'm feeling incredibly frustrated with the micro-banding in the midtones on my 2200. I've
done the nozzle checks/head alignments and even tried lowering the number, as Clayton
suggested - all to no avail. The prints just look terrible, with both vertical and horizontal
banding in any large expanse of mid-gray, but nowhere else. The horizontal lines show up
as three lines quite close together, some space, then three more lines, on down the print,
with the verticals appearing a bit thicker and evenly spaced.
What the h*** am I missing (printing BO, btw)?? I've looked at past posts about this and
don't see anything I haven't tried. Is this a 2200 issue that is improved on other models
like the 4000? Is it my image?
And....has anyone definitively determined that the 3800 prints true BO?
Thanks!
Sarah
Re: less micro-banding on 4000? Please??
2007-02-15 by dizpark
Sarah!
I did look at your original thread re microbanding with BO on 2200,
but I did not have the patience to read it all.  So if what I am
suggesting here has been already tried, forget about it.
I assume you are using the settings as suggested by Clayton i.e.
2880 dpi and with high speed checked. Have you tried printing it
with
a) at 2880 dpi with high speed unchecked.
b) at 1440 dpi with high speed checked
c) at 1440 dpi with high speed unchecked.
Does the banding go away then?
I know the quality will take a huge hit at 1440 dpi and I am not
suggesting to use this for your prints - only to find out what may
be wrong with the printer.
For instance if the banding goes away at 2880 dpi with high speed
unchecked, then I would guess that the culprit could possibly be
incorrectly adjusted Bi-directional printing...
What I am driving at is that you may consider having a go at the
Epson Servicing programme for this printer. This lets you print out
test patterns to determine if the printer is adjusted correctly and
make the necessary adjustments yourself, if you want.  I wrote about
it here:
http://tech.groups.yahoo.com/group/DigitalBlackandWhiteThePrint/messa
ge/83642
I am not suggesting that this would solve the banding problems, but
if you are desperate, maybe it is worth a try.  The cost of service
manual and the service programme is trivial.  However, you have to
account for the time it will take to go through the manual and
perform various tests. It is a bit of a learning curve and time-
eater.
Also for printing certain test targets Epson service manual suggests
using  Epson Photo Quality Inkjet paper - at letter size this not a
big problem, but for certain tests you need the A3+ 13x19 size
paper. As this paper in this size comes at packs of 100 sheets only,
then buying the whole pack just for these tests alone is a waste.  I
think you can use any similar weight matte surface "photo quality"
paper for these tests. I ended up using Epson Enhanced Matte for
this.
Didzis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface"
<sagaface@...> wrote:
> Hi All....
number, as Clayton
true BO?
> Thanks!
> Sarah
RE: [Digital BW] less micro-banding on 4000? Please??
2007-02-15 by Paul Roark
>... frustrated with the micro-banding in the midtones on my 2200. ...
>banding in any large expanse of mid-gray, ...
> (printing BO, btw)...
When I check the "Black Ink Only" box in my 2200 driver I get a message from
Epson: "The Black ink setting is suitable for text or draft printing.  The
print quality is not suitable for photographic images."
My experience is that there are good reasons Epson has this message pop up.
I understand some people prefer BO printing, but the printers are not made
to give consistently good results with only the black ink.  The more inks
that are firing, the more likely the artifacts will be covered up.
http://home1.gte.net/res0a2zt/photos.html
Re: [Digital BW] less micro-banding on 4000? Please??
Well, Paul, you have a compelling point there! I'd forgotten about that message.
Much as I resist, I may have to start exploring other printing options for some of my
images. I will miss the luminosity of the paper showing through with BO, though.
Thanks for that reminder,
Sarah
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...>
> Paul
> www.PaulRoark.com
Sarah,
>... I may have to start exploring other printing options for
> some of my images. I will miss the luminosity of the paper
The next step might be to use QTR and print with just the Eboni and LK.
That too lets a lot of paper show through, but it might be enough to hide
the defects.
Paul...how do I turn the other jets off?
wrote:
> Sarah,
> the defects.
> Paul
> www.PaulRoark.com
In QTR the Warm profiles that are there in the 2200 UC folder sometimes if
not always turn off the color inks and just print with K and LK.  For the
other inks the Curve Creator shows "Not Used."  See if you like those warm
curves.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of sagaface
Sent: Thursday, February 15, 2007 9:21 AM
Subject: Re: [Digital BW] less micro-banding on 4000? Please??
wrote:
> Sarah,
> the defects.
> Paul
> www.PaulRoark.com
> http://home1. <http://home1.gte.net/res0a2zt/photos.html>
2007-02-15 by Joost Horsten
made
inks
That may be true, and I'm by no means a hard-core BO adept (being
perfectly happy with my UT3D inks), but once in while there is an image
that just beckons for a BO print. Of course it's not as smooth as when
firing three or more inks, but it prints just fine on my 2100. No
banding whatsoever.
2007-02-16 by sagaface
Thank you, Paul. I will give this a shot. I'm happy to expand my options and this seems a
good place to begin.
Thanks again!
Sarah
> curves.
> Paul
>   _____
> eThePrint@yahoogroups.com, "Paul Roark" <paul.roark@>
> wrote:
> > Sarah,
> > the defects.
> > Paul
> > www.PaulRoark.com
