Newbie Printing Questions. Please bear with me.
2007-03-02 by Steve
Hi there, long time lurker...and all that.
I'm considering buying a large format printer.  My primary uses (in
order of importance) would be:
1) Digital negatives for cyanotype/van dyke prints
2) Black and white prints (a secondary use, but I feel I may fall in
love with this)
3) Color prints (I actually see this as quite rare).
I've just about talked myself in to the piezotone system for black and
white.  I particularly like the possibility of doing split tone prints.
I am considering a refurbished Epson 1280 (a bargain at $200 after
rebates).  My next choice would be a refurbished Epson 1800 at about
$380.
Because I think just about any printer at this quality level can
handle the demands of my digital negatives, the choice really comes
down to how well I will like black and white prints made with the
piezo inks.
So, how good are black and white prints with the 1280 and the
piezotone system?  Am I likely to regret not getting the 1800 based on
print quality alone?
Any other recommendations?
Thanks
I can use a CIS with either printer (and if I start printing my own
black and white, I'll do that), so ink costs should be about the same.
RE: [Digital BW] Newbie Printing Questions. Please bear with me.
2007-03-03 by Paul Roark
If I were doing digital negatives, I'd be real interested in what the new
Epson 1400 could do.  The general feedback I'm hearing is that it really is
sharper.
See
http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=ye
s
<http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=y
es&oid=63066043> &oid=63066043
That printer will not do B&W with those inks, however.
You will want glossy paper compatibility.  That might knock out the
Piezotones.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Steve
Sent: Friday, March 02, 2007 1:17 PM
Subject: [Digital BW] Newbie Printing Questions. Please bear with me.
love with this)
$380.
piezo inks.
Thanks
Re: [Digital BW] Newbie Printing Questions. Please bear with me.
2007-03-03 by Steve
the new
really is
> sharper.
> See
BV_UseBVCookie=ye
> s
BV_UseBVCookie=y
> Piezotones.
> Paul
>   _____
Steve
me.
in
> love with this)
and
prints.
> $380.
> piezo inks.
on
> Thanks
same.
So, the piezotones don't work on glossy papers?  If so, they must not
work on OHP....
That would have me switching back and forth between epson color inks
for digital negatives and piezotones for black and white prints.
Can anyone confirm this?
2007-03-03 by koloshor
the new
really is
> sharper.
The 1400, with the stock inks, should be fine for digital negatives
for UV exposed alternative processes like Steve's Cyanotype and
Vandyke brown.
http://www.hybridphoto.com/forums/showthread.php?t=223
Sandy King measured 1400 transparencies on a UV densitometer (I really
need to get myself one of those) and found Claria hit a density around
1.85, and most alternative processes don't need much more than 1.6.
Carbon pigment inks exceed 2.4 and can work for any process, that's
why I do my negs on a machine loaded with 100%, 32%, 10%, 3.2%, and 1%
PKN. (As soon as the last of that is gone, the new set uses MIS-PRO
with my own neutralized black, since MIS doesn't want to do PKN with
the PRO inks).
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve"
> work on OHP....
It depends on how you define "work on OHP".
Piezotones are "matte black" inks. They're really concocted to go
slightly into the surface of a fibrous paper. On a smooth resin coated
paper (or film, like OHP or HGW) they stay on the surface, and have a
"sooty" appearance. They don't bond well to the surface, and can rub
off. A quick coat of "print shield" (or probably even Krylon) can
neutralize that.
The advantage of using a matte black for a digital negative is that
you can build tremendous density, up to about density 4 (I can't
measure 4, I determined it by running 10x as long an exposure with the
digital neg as with the Stofer step wedge).
Personally, I don't find that extreme density useful for any process,
and typically print all my digital negatives without the use of any
"matte black" component.
My own B&W is done with something I cobbled together with two MIS
inks, dilutant, and the glop "gloss coat". For digital negatives, I
use 5 dilutions (100%, 32%, 10%, 3.2%, and 1%) of MIS PKN ("neutral"
carbon black).
For matte papers, those same five PKN dilutions, plus MIS "eboni" as
the matte black. For gloss, the five PKN dilutions plus glop, and no
eboni.
Hey, have I talked to you on another forum recently?
2007-03-03 by Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "koloshor"
not
> > work on OHP....
inks
coated
a
> neutralize that.
process,
> carbon black).
> eboni.
So, it sounds like I'm going to have a hard time doing digital
negatives with the same printer I would like to have dedicated to
black and white.
Switching back and forth from color to piezo sounds like no fun at
all.  The web site says it's easy, but my limited experience with
printers would say I'll have a hard time at it.
I'm on several forums, I'm not sure if we've spoken elsewhere.  I'm
often on rangefinderforum.com and sometimes fredmiranda.  I help
moderate a small forum for manual focus lenses as well.
2007-03-04 by Paul Roark
>with two MIS inks, dilutant, and the glop "gloss coat".
>For digital negatives, I use 5 dilutions (100%, 32%,
> 10%, 3.2%, and 1%) of MIS PKN ("neutral" carbon black).
By the way, 32% PK is LK; 10% PK is essentially LLK; 3.2% PK is close to the
old PiezoBW quad Y position.  1% PK is ... (barely gray water?)  That's one
very dilute ink.  Do you find it actually ads something to the printing?
I mixed the PKN to get a better dmax on glossy papers.  I wonder what impact
the blended color inks (cyan and R800 blue mixed with the carbon) have on
the digital negative process.
I'm surprised you find the blend pleasing outside the shadow areas in normal
inkjet printing.  Usually it's a bit cyan outside the shadows.
2007-03-05 by Steve
> the new
> really is
> > sharper.
> Vandyke brown.
really
around
1%
> the PRO inks).
I imagine piezo inks will eventually be available for the 1400????
I'm waiting for an answer from the piezo ink people as to whether or
not I can use their ink system on OHP for my digital negatives.
2007-03-05 by Clayton Jones
Hello Steve,
Please trim your posts of all non-relevant verbiage (as I have done
here).  Leaving in the entire thread trail with all it's symbols and
line breaks makes your posts extremely difficult to read.  Thanks very
much.
Clayton
Re: Newbie Printing Questions. Please bear with me.
2007-03-05 by Jeff Randall
I've owned 3 1270/1280s.  All started out OK and gave good results,
but with use all developed significant clogging issues.  I recently
switched to an Epson refurbed 1800 and not a single problem after
running over 700 prints.  The 1800 is "designed for pigment inks and
is well worth the extra expense. It has a more modern printhead
design and individual carts -- a significant stepup, imo.  YMMV.
I use Paul Roark's K4+Ccm system based on MIS inks and QTR to
generate my proiles.
(in
in
> love with this)
and
prints.
about
> $380.
comes
> piezo inks.
based on
> Thanks
own
same.
