BW workflow - input please
2007-03-11 by pglombick
I am using PS CS2 on Windows XP and a Epson R2400 and K3 inks. I can't afford additional equipment right now for profiling or calibrating, so I just use the built-in Adobe profiling utility and will have to make do for now. I am looking for advice on which setting to use in PS CS2 to get the best chance of WSIWG or something relatively close. I am a complete printing neophyte, so any input would be appreciated. Specifically, I am not sure whether to select no color management or let PS determine colors and whether to select a canned profile for the ink/paper combo I am using, and if so where to select it (while wokring up the image) or during the printing. Also, I don't know whether to select dot gain 30 or gamma 1.8 or 2.2. Using 2.2, things seem a bit dark with blocked up shadows. Any additional prining tips or advice you can add would be appreciated. Strangely, using Piezo K7 inks, Quadtone RIP, and the canned profiles, I get very good results everytime, but I have had very bad clogging issues and the cost of running endless cleaning cycles have led me to try the K3 inks. Also, it would be nice to print glossy sometimes. Thank you.
