C88 Issues and Questions
2007-03-22 by heningerw
I'm having a hell of a time getting decent prints with a new C88 and the MIS EZ inks.
I've been all thru Paul's settings documents several times and tried all kinds of variations, but
I'm just not getting very good prints.  Not good at all.
So my question is:  with the 4 ink set from MIS, do I print in "color" or do I do "Black"?  Black
seems to be much better, but then why would they sell me four inks if the quality is so poor
printing with them?
I've tried reams of different paper:  EEM, Kirkland (from MIS), Canon Glossy, Epson Glossy, HP
Glossy, Konica glossy (had a bunch of this on hand), Crane Museo SR and Innova F-type
Glossy.  The latter two papers look much better, but they should - they are beautiful papers
and they cost it.  I got this system to proof print stuff using cheap paper and save my 2400
for final printing.
Comments anyone?
Re: C88 Issues and Questions
2007-03-22 by Jeff Randall
Hard to help.  Specifically what do you mean by not good prints?
This may be something as simple as a monitor/printer mismatch (ie,
no WYSIWYG).  Is your monitor calibrated?  Even if it is, you may
still need to apply a curve to your monitor image (or a proofing
profile) during editing to get a good match (or to your image before
printing).
Yes, print in color.  The Black setting only prints with one black
ink.
I recommend starting out with EEM (inexpensive) until you sort out
your workflow then go for the other papers.  Minimize the variables.
Others will have to help you with the specifics of the C88 and MIS
EZ inkset.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "heningerw"
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jeff Randall" <jrandall@...>
Flat.  Purplish. Poor gradations in the tonalities.  In short, they look like complete crap.
This system is to be my proofer - not the final image printer - but these don't even pass
as proof prints.
> printing).
Yes, my monitor is calibrated.  Yes, I tried softproofing the images in PS as well.  I tried
print with the profiles Paul provides as well with no real benefit.
> ink.
Printing in color looks like complete crap.  Black looks much better.
I'm a darkroom veteran, so I know all about that.  I focused on EEM and Kirkland.  I only
did the test with the other glossies to see what I got.
Re: [Digital BW] C88 Issues and Questions
2007-03-22 by ann clancy
i have been "playing" around with the c88+ and the MIS inks.
  the first batch of inks worked out very well, infact , i was quite surprised.  Using Paul's suggestion as well along with the Kirkland paper.
  The second batch of inks has been another problem, even using the same image and same numbers they are not very good.
  All sorts of issues, and since i am not sure what i am doing it can be madding.
  As you, i have many years of darkroom experience and have to remind myself at one time it was just as overwhelming.
  Just to let you know your not alone lol
  regards,
  ann
printing with them?
for final printing.
Comments anyone?
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, ann clancy <jaclancy1937@...>
Thanks Ann.
I wonder if this really is a "batch" problem with the inks?  Has anyone else had consistency
problems with the MIS inks?  This would be a very disturbing variable that would throw
quite a kink in the line...
RE: [Digital BW] Re: C88 Issues and Questions
2007-03-22 by Mike Johnston
The C88+ works great for me.
Which set of inks did you get?
Are they in the correct slots?
Are you using the icc method? If so which profile are you using?
What OS? What software do you use to print?
Mike J.
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of heningerw
Sent: Thursday, March 22, 2007 9:22 AM
Subject: [Digital BW] Re: C88 Issues and Questions
<jrandall@...>
like complete crap.
don't even pass
as proof prints.
> printing).
as well.  I tried
> ink.
Kirkland.  I only
2007-03-22 by Jordan Wosnick
I've had strange "tonality" issues with the C86/MIS-EZ combination when
one cartridge wasn't "firing" properly. Could be a defective cartridge
or an air bubble trapped somewhere?
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, ann clancy
> <jaclancy1937@...>
> same image and
> be madding.
> myself at one
> Thanks Ann.
> that would throw
Jordan Wosnick
jwosnick@...
Re: [Digital BW] Re: C88 Issues and Questions
2007-03-23 by Kip Babington
Here's another satisfied C88/MIS EZ user.  I've been using the EZ inks
for several years now, without complaint.  Mostly with a MIS CIS in a
C84 and now a C88, but I also have a second C88 with the EZ inks in
refillable cartridges.  (I printed a bit over 1,000 images in the month
before Christmas last year, and things seemed to go a bit faster if I
alternated sending batches to the "primary" printer with the CIS and the
"backup" with the cartridges.)
Kip
> Mike J.
2007-03-23 by Fred59
I am NOT familiar with the C8x setup--but I have an R340 and the MIS
UT-R2(N) setup.  If the drivers are somewhat similar, then--
1.  Check your printer PROPERTIES (select printer in 'printers and
faxes,' right-click, scroll down to Properties) have the correct
color management setup (select Color Management tab in Properties.)
If there are ANY profiles assigned to the printer and the CM is set
to automatic, then
a.  DELETE ALL PROFILES, and
b.  set CM to Manual.
2.  In the Printer Driver, look to see that "ICM" is enabled, and
that the "ICM OFF" box is checked.  Look on the "Advanced" tab, I
suspect.
This for sure puts your Editor in control of the file sent to be
printed.  Your image in Edit will, if your monitor is calibrated,
look pretty much like what you want it to--
3.  If you're now getting nominally the print you want, you can now
go in and use the Printer Color Controls (select Color Control, not
ICM / ICM OFF) and you can tweak the prints as desired.
4.  FWIW, I convert my prints to B&W in my Editor (PSE 5.02), and I
assume you are doing that.
You're probably much more advanced than I am right now, but this is
what I've sorted out for B&W printing so far.  But, I've found that
(apparently) XP keeps reassigning my monitor profile to printers in
the Printer Properties; that's a hidden feature I could do without.
Jim H.
2007-03-24 by guangchengshui
I have been using a C88 with the MIS Neutral Inks with Eboni black for a couple months
now, and have been making great prints with it.  Granted, this is my first batch of inks so I
cannot comment on batch consistency.  I am also a darkroom veteran and find this to be a
great printer for small proofs.  I have been printing mostly on HPR.  I use Gray Gamma 1.8
as my working space and the QTR-HPR ICC profile that I got with the Quad Tone Rip.  I
usually have to apply a curve layer to lighten the image for printing (it prints kind of dark
otherwise).  In the print driver settings I use the advanced tab, setting it to the highest
resolution, heavyweight matte and turn ICM color off.    If you haven't downloaded Quad
Tone Rip for the profiles, you definitely should.  Hope this helps.
-Chris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Fred59" <jfhanson45@...>
> to automatic, then
> suspect.
> Jim H.
