QTR profiling and partitioning
2007-04-19 by Paul Roark
I'm not the most experienced QTR profiling person, but I've been seeing what might make the process faster and more accurate from my perspective. Here are a couple of things I've found that might become part of my general QTR profiling procedure. First, I think a smooth are relatively linear carbon core is needed. I think a linear core makes for more even toning and a more linear final result. I was not satisfied that the QTR controls in the gray tabs were sufficient. So, what I've found works rather well is to use QTR's partitioning procedure, but when the Create Curve button is pushed, use a screen grab to copy the curves. Then go to Photoshop and simply copy those curves' coordinates to *.acv curves. The PS curves can then be rather easily refined to achieve an excellent carbon core. These PS curves are imported back into QTR for the individual gray inks. The resulting linear (even before final linearization) core is then used for all the profiles for that type of paper. This basically gives us perfectionists the advantages of Roy's partitioning algorithm as a starting point, but with none of it's limitations. The second thing I've found very useful is to set the LC and LM (toner) ink limits by simply printing a few 50% patches with straight line curves for LM and LC. This is very fast. The straight line curves are simply entered into the Points List tab as (0, 0) and (100, 100). Once the 50% patch is the tone I want, the curve is simply turned around at about 85% to 90% so that the curve ends at (100, 0). By getting the light inks out of the 100% patch, the dmax is increased about 0.05 - worth the effort. I use *.acv curves to be sure the turn around is smooth. I stick some points at (25, 25), (50, 50), and (75, 75) to be sure the "curve" stays straight for the most part and the same as the (0, 0) to (100, 100) initial test curve. The PS curves can be used by QTR or the points can be put into the Points List tab to make future modifications easier. (It's easy to lose track of PS curves that are not accessible from the QTR profile itself, and other users would not have the originals.) Many will simply linearize these basically straight line curves and be done with it. Others (like me) will find tweaking a bit worth the effort for some purposes. Paul www.PaulRoark.com <http://www.paulroark.com/> [Non-text portions of this message have been removed]
