Re: [Digital BW] Softproofing with ABW
2007-05-31 by CDTobie@aol.com
In a message dated 5/31/07 12:37:25 PM, caostebbins@... writes: > I do have a question regarding softproofing and ABW, however. Is there a > way I can see a > softproof using ABW? > There is no way to softproof generic AWB results, as they are not ICC profile based. Thats a big part of what a custom profile is for: to show you what you'll get before you print it. This allows you to tweak images to a particular printer/ink/paper combination. It also allows you (when doing color work) to control how out of gamut colors are brought into gamut yourself, to avoid suprises when you leave it to the profile and rendering intent to do it for you. But to get an accurate preview, you first need a custom profile. The Atkinson profiles are not applicable to AWB, so won't be of any assistance there. I print my B&W through the Epson color mode, as I find that more effective and accurate. I can select an image, use Photoshop's Custom Proof Setup option to view my image through the profile. With a ColorVision profile, you should then turn Black Point Compensation OFF, and both ink black and paper white emulation ON. This gives you a softproof of how your image will print. You can adjust the relationship of ink black to monitor black for your PFP profiles by using the Reference Black feature (see the help on that screen for details) and the Reference White feature to tune your paper tone softproof. I haven't tried all these fine tune features with a profile for B&W mode, since I don't find that the most effective way to print, but I suspect that they would be usable for softproofing of profiles for B&W modes, since they are used in Photoshop in advance, not used in the driver. But if you use any of the adjustments in the B&W mode to tint your prints, that won't be reflected appropriately in the profile softproof, unless the adjustments were used in the original target print. If you print in color mode with a PFP extended grays profile, you will get an accurate softproof for your neutral prints, and the ability to softproof any tinting you care to add as well. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed]
