Re: [Digital BW] Ink Comparison of Epson ABW and regular drivers
2007-05-31 by CDTobie@aol.com
In a message dated 5/31/07 1:34:03 PM, roy@... writes:
> Some observations:
> ABW uses a lot more LLK --- 16 times!
> ABW uses a lot less Y   --- 1/4 the amount
> ABW uses no dark C and M
> Interestingly this really supports the idea of replacing the Y
> ink with a LLK ink with either driver.
Yes, and it would support the idea of custom profiling the color output in
color mode after you replace the yellow cart. That would let the profiling
software adjust the neutrality blend of the light components, eliminating not just
the yellow, but a good bit of the other colors as well.
On the other hand, with a custom profile (I can't speak to the Stock Velvet
profile) I find even the straight color ink mode's B&W to be low enough in
yellow to be visually free of illuminant metamerism, so we may be splitting hairs.
I don't find the Canon color mode to function quite like the Epson AWB mode;
seems to be less color ink, and more light light gray in it in all modes,
though I don't have a handy tool to quantify that, like the ink drop info from the
Epsons...
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@colorvision.com
www.colorvision.com
 See what's free at
http://www.aol.com.
RE: [Digital BW] Ink Comparison of Epson ABW and regular drivers
2007-05-31 by Eric Neilsen Photo
Perhaps, It is more an indication that Epson has really been paying
attention to the needs of the B&W digital printer and tried to eliminate the
undesirable outcomes. It would be interesting to see the ink usage of a
neutral ICC profile, made by PFP, an EYE One set up, etc., to see how they
stack up. However, unless you are only printing B&W I see no reason to fret
about .87% yellow ink. Those needing a system that does both would be better
off leaving things be and those printing only B&W might be better off with
just a dedicated ink set with toners included within the more neutral ink.
Eric
Eric Neilsen Photography
4101 Commerce Street, Suite 9
Dallas, TX 75226
214-827-8301
Skype : ejprinter
  _____
CDTobie@...
Sent: Thursday, May 31, 2007 12:52 PM
Subject: Re: [Digital BW] Ink Comparison of Epson ABW and regular drivers
In a message dated 5/31/07 1:34:03 PM, roy@harrington.
<mailto:roy%40harrington.com> com writes:
> Some observations:
In a message dated 5/31/07 2:30:06 PM, e.neilsen2@... writes:
> stack up.
How they stack up in other respects might indeed be interesting, but there
would not be any meaning to looking at the ink usages between them; all an RGB
profile can do is ask for R,G, and B. It can't tell the driver how to define
channel splits, or ask it to eliminate components.
Toners included in the neutral inks are still toners. It doesn't much matter
if that yellow ink is mixed into a gray ink or not, it will still cause the
same degree of illuminant metamerism, or the same degree of fading, as the case
may be, ; plus it will add the highly undesirable situation of mixed inks with
differential settling and differential moving in the lines. Inks built out of
pure, single tone pigments are a much better deal for B&W inksets than ones
with colored toners added.
If you are going to add color, adding it directly from a color cart offers
the advantages of knowing just how much you're going to get, and allowing you to
choose how much you want. I'd certainly love to see the next generation of
Epson drivers reduce the percentage on color inks for neutrals even further, to
minimize the issue at even a theoretical level.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
David, That is how they stack up to the ABW in terms of ink usage, not to
one another; i.e. a neutral ABW setting and a neutral profile not just
printing a grayscale image with a profile intended for color printing.
Toners within an ink set like the Piezotones selenium, and sepia tones that
may or may not be single pigment solutions. I don't know. I didn't mean
toners as in using a color pigment like LM, LC, etc.
Dallas, TX 75226
214-827-8301
Skype : ejprinter
  _____
CDTobie@...
Sent: Thursday, May 31, 2007 1:49 PM
In a message dated 5/31/07 2:30:06 PM, e.neilsen2@worldnet
<mailto:e.neilsen2%40worldnet.att.net> .att.net writes:
> stack up.
RGB
better
case
with
of
you to
to
C. David Tobie
Datacolor Inc.
CDTobie@colorvision <mailto:CDTobie%40colorvision.com> .com
www.colorvision.com
See what's free at
http://www.aol. <http://www.aol.com.> com.
