Re: [Digital BW] Setting the black and white point
2007-06-12 by CDTobie@aol.com
In a message dated 6/11/07 5:31:10 PM, cieloblu@... writes: > This may be a bit off topic...however, does anyone know a good way to > set the white and black point in a digital projector? My black and > white images get slaughtered in digital projection even though they are > created in my monitor calibrated computer system. We have tried a 21 > step grayscale and it is roughly okay. But delicate detail in shadows > and highlights can still get abolished. Help! > Are you attempting to set black and white luminance (brightness of each) or black and whitepoint (color balance of white and black)? Spyder2PRO calibrates projectors, but does not attempt to control these rather variable elements of it. Black luminance for a projector is defined by room lighting (ambient light). A brighter room means a weaker black as the screen gets less dark. White luminance varies with how far the projector is from the screen, how bright the bulb is, etc, but the eye adapts to this very quickly, and no adjustment is needed unless multiple projectors are to be matched. Black balance can only be adjusted by RGB Bias controls, which few projectors have, and few users would need to adjust even if they had them. White balance is controlled by the eye's whitepoint adaptation. Unless you are running two projectors at once, there is really no reason to work with RGB gains on a projector, as your eye will adapt to whatever is there very rapidly, including making a colored wall look white if you project on it. So, given the variable and adapative nature of all these factors, they are not controlled as part of projector calibration. There is a tech tip on this topic on the ColorVision website, if you want to read a bit more. http://www.colorvision.com/learn_expert.php C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed]
