Green cast on R2400 ABW prints
2007-06-16 by compilerbitch
Recently, I've been having problems with my ABW prints having a slight
(but unacceptable) greenish-blue cast. I'm using a r2400 with the
standard K3 inks. I've run a head cleaning cycle, and the test pattern
looks OK. The problem is quite subtle, but very apparent if you
compare prints I've done recently with some from a few months ago.
Any suggestions as to what might be going on?
Thank you in advance,
Sarah
PS: Sorry if this message turns up on the list twice -- I think my
first attempt to send it failed, though it's possible that the first
message may just be delayed.
Re: Green cast on R2400 ABW prints
2007-06-17 by Clayton Jones
Hello compilerbitch,
>slight (but unacceptable) greenish-blue cast. I'm using a r2400
>with the standard K3 inks. I've run a head cleaning cycle, and the
>test pattern looks OK. The problem is quite subtle, but very
>apparent if you compare prints I've done recently with some from a
>few months ago. Any suggestions as to what might be going on?
Did you just change a LM cart?  I've experienced on two occasions
differences in LM intensity after changing a cart.  This can effect
the magenta/green balance.  The first time it was a very slight
difference, the 2nd time was more pronounced.  I assume it's
differences in production batches.
Clayton
