Epson 1280: New liquid diet, or the landfill?
2007-07-06 by Peter A. Klein
I've mentioned before on the list that I've had troubles with my
Epson 1280 with MIS Ultratone 2 carts.  I've now had several
instances where I changed cartridges, and either the greytone
distribution or the "tint" of the prints changed. A while back, my
Roarke curves workflow, which had worked for 2 years, just stopped
working. Gray tones were skewed or missing. Both with the Epson
driver and with QTR, which eliminates driver problems.
Well, it just happened again.  This time I changed to a new grayscale
cart, and my "neutral" workflow (EZ Slider method) turned distinctly
bluish.  Changing the sliders to the "warm" settings does little to
change this.
And there are no clogs.  Every nozzle check I print comes out fine,
but the prints come out bluish. The Sepia ink prints out lighter than
it should on the Purge Pattern 6 file (compared to an earlier cart's
printout of the same file).
I should also mention that when I print a Black-Only print, I get
slight to moderate banding. But if I print the same image twice in a
row, the banding will be in different places.
It's possible it's the cart, but I'm coming to the conclusion that
it's my printer. Unless MIS has much worse quality control than their
reputation, it's just happened too many times for it to have been
MIS' fault every time.
So here's my question:  If it is indeed the printer that's the
problem, what are the chances that the problem would go away if I
went back to the dye inks the printer was designed for?  In other
words, supposed I went back to color dye inks on the 1280, and
switched to UT-R2 grayscale inks in my R200?  If it worked, I could
delay buying a 3800 for a while, and my finances would thank me.  If
it didn't work, I'm out a hundred bucks of ink and some more
frustration.
If there's a good chance that my problems are some long-term
consequence of using pigment inks in a printer designed for dyes, I
might chance the color/BW switch.  If it's more likely that my 1280
is just slowly dying, maybe it's time to pull the plug.
--Peter
Re: Epson 1280: New liquid diet, or the landfill?
2007-07-06 by Philip Schwartz
my advice: dump the 1280. I have run a few different MIS ink sets in a
couple of R200's including UT-R2, and they make prints of outstanding
quality. My 1280 was slow and unreliable compared to the R200, so the
last time it quit printing I just tossed it.
If you are really adventurous you can use MIS ink in an R800/R1800
with QTR. With 1.5 picoliter droplets tones are very smooth and there
are no dots visible in the highlights even using a 10x loupe.
Re: [Digital BW] Epson 1280: New liquid diet, or the landfill?
2007-07-06 by Charles Becker
Pull the plug.
"Peter A. Klein" <pklein@...> wrote:          I've mentioned before on the list that I've had troubles with my
change this.
frustration.
--Peter
Boardwalk for $500? In 2007? Ha!
Play Monopoly Here and Now (it's updated for today's economy) at Yahoo! Games.
