can't center image on page
2007-07-07 by davidlhoste
I am using a Epson Stylus Photo 2200. No problems until I loaded PS
CS3. Now although I check "center" in the PS dialog box and in the
printer dialog box, the image appears on preview aligned in top left
corner of page. It also prints this way. I then installed the latest
driver for the 2200, with the same results. Any help in figuring out
what is going on will be much appreciated. Thanks.
Re: [Digital BW] can't center image on page
2007-07-07 by Debbi
Make sure you also do the 'page setup' before you do the 'print'
option. I have  the R2400 and it does make a difference with that
one. Not sure about the 2200, but you can try it.
Debbi
2007-07-07 by bwinkjet
Yes, do page set up and on the second tab be sure to minimize
margins.  This is a change in the driver interface with PS CS3 that
some people find a pain.  This is peculiar to the 2200.  My 3800 is
not so picky.
HTH
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Debbi
> Debbi
left
latest
out
Re: can't center image on page
2007-07-07 by robert49brake
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "davidlhoste" <davidlhoste@...>
As mentioned, in the Page Setup make sure your printer is selected in the "Format For:"
dropdown box if "Any Printer" is the default.  You may find that "Any Printer" is the default
every time you open the printer dialogue and you'll need to change it.  That problem I think is
Mac centric and goes back a long time.
