Re: [Digital BW] Info on using Printfix Pro with UT-3D inks and QTR?
2007-07-11 by CDTobie@aol.com
In a message dated 7/11/07 2:02:34 PM, rcooke@... writes:
> Does the above combo allow a user to get good results easier/quicker
> than using QTR alone?  I have the i1 photo but as far as I know it
> won't help in B&W printing with the UT-3D inks on my 2200.  If the
> Printfix Pro has some "magic sauce" that will allow me to use
> different papers without multiple trial and error prints then I'll
> sell my i1 and buy the Printfix Pro.
> I assume that I'd profile a paper using Printfix Pro using the
> extended grays target which yields an ICC profile.  The next step is a
> bit foggy to me.  If I want to mimic the Lenswork tones on a new paper
> will the ICC just produced by the Printfix Pro be used by QTR?  Is
> there a reference that might describe this process somewhere?
You can use PrintFIX PRO as you describe with UT-3D inks, and the RGB driver.
Or you can use them with QTR, and use CreateICC to build your profiles,
measuring for them with PrintFIX PRO's measure tool, but not building the profiles
in PrintFIX PRO. These are two seperate methods. To mimic tints or crosstones
using PFP and the RGB driver is fairly straightforward. I can't comment on the
process of creating custom tones curves in QTR.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
2007-07-11 by Richard Cooke
Thanks C. David.
I have one more question - does the RGB driver method use all of the
inks in the set?
Thanks again,
Richard Cooke
RGB driver.
crosstones
comment on the
> C. David Tobie
> Datacolor Inc.
> CDTobie@...
> www.colorvision.com
>  See what's free at
> http://www.aol.com.
In a message dated 7/11/07 2:41:27 PM, rcooke@... writes:
> inks in the set?
Yes, though the amounts it uses of each depends on the tints you choose to
print...
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
