Crane Portfolio Rag DMAX
2007-08-01 by Terry Ritz
I picked up some Crane Portfolio Rag samples to try. It a beautiful
paper, and I have high hopes for it. However, all I'm getting for DMAX
is 1.54 using Cone K7 inks.
Is this consistent with the results of others? What kind of DMAX (K7
inks or otherwise) are the rest of you getting?
For reference I get about the same (1.55) with Premier Art Hot Press
but Innova Smooth Cotton & Soft Texture Art are significantly higher
at 1.64.
Terry.
Re: Crane Portfolio Rag DMAX
2007-08-01 by Tyler Boley
I can't remember what I  got on it, but it was certainly not up to
what we normally expect and I bagged it. Check all your densities
between 90% and 100%, it shoulders over and you may find a limit spot
with higher density.
Fail to see what people like about this paper compared to the options,
other than it's tough coating. Pretty low total ink capability as
well. Very persistent hard curl from rolls.
Other than all that, gorgeous stuff! <G>
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Terry Ritz"
> at 1.64.
> Thanks,
> Terry.
I'm looking for a paper with a nice, smooth surface for portrait work
and reproducing artwork (pencil drawings). This is where PAHP and
Portfolio Rag have came in. It's been a while since I tried HPR, but
maybe I should try a few sheets. There's something about Innova Smooth
Cotton Bright White that doesn't quite work for me (paper tone?) but
it's certainly an option.
Other suggestions?
Portfolio Rag has a very low ink load, lower than anything else I've
used. I do like the surface and tone of the paper, although something
a bit warmer might be nice. The low DMAX is an issue however.
Terry.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
> Tyler
> > at 1.64.
> > Thanks,
> > Terry.
Re: [Digital BW] Re: Crane Portfolio Rag DMAX
2007-08-01 by Michael King
Terry,
Using 4800 with K7 and ABW I am getting a much better dmax on Portfolio rag
extra smooth, I am getting 1.64 (using the Textured Fine Art paper setting).
This is better than I get with Hahnemule Portfolio Rag (1.59), not as good
as Velvet Fine Art (1.76).
I quite like the paper.
Mike
> Other suggestions?
> Terry.
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>,
> "Tyler Boley"
> > Tyler
> "Terry Ritz"
> > > at 1.64.
> > > Thanks,
> > > Terry.
Just to clarify I am using standard Epson inks with ABW mode not K7 sorry
for the confusion.
One glass of wine too many by 9pm :)
Mike
On 01/08/07, Michael King <drmrking@...> wrote:
> Terry,
> rag extra smooth, I am getting 1.64 (using the Textured Fine Art paper
> setting). This is better than I get with Hahnemule Portfolio Rag ( 1.59),
> not as good as Velvet Fine Art (1.76).
> Mike
> > Other suggestions?
> > Terry.
> > "Tyler Boley"
> > > Tyler
> > "Terry Ritz"
> > DMAX
> > > > For reference I get about the same ( 1.55) with Premier Art Hot
> > Press
> > > > at 1.64.
> > > > Thanks,
> > > > Terry.
Interesting. . . .  I'm using a 2200 and QTR. I'll have to look
closely at my step wedge under a loop and perhaps play with the Gray
Overlap parameter in QTR. I should also cross-post this to the QTR group.
Thanks. . .  very helpful info.
Terry.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael King"
> Terry,
Portfolio rag
setting).
as good
> Mike
That's too bad!!  ;-)  Guess you can ignor my last post, although I
will look at my 100% black patch more closely.
Terry.
sorry
> for the confusion.
> Mike
> > Terry,
Portfolio
1.59),
> > Mike
You should be able to get at least as good if not better dmax with Crane
than Hahnemule.
> Terry.
> "Michael King"
> sorry
> > for the confusion.
> > Mike
> > > Terry,
> Portfolio
> 1.59),
> > > Mike
I've been using Innova papers and it's been a while since I tried any
HPR. I'll have to pick up a few sheets of Photo Rag to see what I get.
This may also be an ink/paper combo issue, as I know Tyler uses Cone
inks. However, I'm not sure if he used K7 or the older Cone inks when
he tried out Portfolio Rag.
Terry.
> than Hahnemule.
2007-08-02 by john dean
He uses the older Cone Quad inks, plus another portfolio black as an
underprinted kicker. But this is all through Studio Print.
I've used a couple of rolls of the Crane Portfolio Rag and personally
like it. Especially for use with the Cone K7 Sepia inks. That is a
very nice combination. It is a natural paper with no oba content, so
it is less white than Photo Rag. This Portfolio Rag is a really nice
smooth sharp paper though and is wonderful for small warm prints in my
opinion. My dmax is slightly less than Photorag with K7 Cone neutrals
and sepia but not really noticeable to me.
The deal with all the Crane matte rag papers is that they bottom out
on ink limits very quickly. So, they absolutely need to be carefully
linearized for the given inkset and printer. With all the Hahnemuhle
papers and most of the Innova matte papers you can throw a lot of pure
black at them and not get motteling. Not so with Crane. Too much ink
and your dmax reverses quickly. If you are making a curve with QTR,
limit the ink.
John
> Terry.
Crane
> > than Hahnemule.
2007-08-02 by Tyler Boley
and same result with UCK3 as well.
Tyler
> limit the ink.
> John
> > Terry.
> Crane
> > > than Hahnemule.
