3MK - What am I doing wrong?
2007-08-03 by Eric Miner
Hello All,
  I've been lurking here for a long time....learning from you and applying what I've learned.
  I started B&W with an R800. After following things here I added an R220 for BO. So far the bulk of my B&W work has been on the R220. My first inkset was Piezography K7 on the R800.
  On the R220 I've played with both Piezo and MIS inksets and with QTR and the Epson driver. My current favorite results come from Piezo K6 inkset set using the Epson driver rather than QTR, I know this is not how it was designed, but the results are great.
  When I saw that MIS was offering an inkset that allowed for BO printing on the R800 I jumped at the chance. I was expecting to see very high resolution prints akin to the color images the R800 has produced for me. But, that was not to be.
  In comparison to the R220 (using the Epson driver or QTR) the resolution I get from the R800 with 3MK is barely acceptable. In the midtones through the highlights the droplet size is very large, much like what I used to see on my old Stylus Photo 870.
  Is it something I'm doing wrong? My QTR settings for printing on the R800 with 3MK  using Moab Kayenta are -
  Paper Type - Photo Quality Inkjet Paper and Matte Paper
  Resolution - 2880 dpi
  Speed - Uni-directional
  Curve - 3MK-MoabKayenta
  Curve Blending is left at default
  I'd like to get the resolution from the R800 that I know it can produce. Can anybody give me any pointers on how to fix this issue?
  Eric
RE: [Digital BW] 3MK - What am I doing wrong?
2007-08-03 by Paul Roark
Hi Eric,
The MIS R800 setup is based on my workflow that is described at
http://www.paulroark.com/BW-Info/R1800.pdf
The 100% Eboni MK is not going to match the smoothness of the modern
dedicated B&W workflows.  On the other hand, the roughness you seem to be
seeing may be a more than expected.  I'd use some Epson Premier Art
Scrapbook paper and the settings that are shown in the PDF as a standard.
Of course, check the nozzles.
Good luck with the setup.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Eric
Miner
Sent: Thursday, August 02, 2007 8:09 PM
Subject: [Digital BW] 3MK - What am I doing wrong?
Hello All,
what I've learned.
not to be.
Eric
