> Alan and Tyler,
> Thanks for the replies. I am still befuddled by this. On most of my
> files (all tiffs) when I add an adjustment layer it increases the
> file size by about 3x. I am not using masks on these file. If I
> delete the mask from the channels tab, the file size goes down a bit,
> but not to the original file size. Every once and a while I'll try it
> on a different file and it works fine. This is using the exact same
> procedure. I have tried using the adjustment layer icon on the layer
> tab and the add layer from the menu. No difference. I'm sure I am
> just doing something stupid, but can't figure out what.
> Thanks again for any help.
> Peter
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
> <tyler@> wrote:
> > are you using a mask?
> > Tyler
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Alan Kearney"
> > <alan_kearney@> wrote:
> > > Peter, I've just started reading Diallo's book but I tried your
> > description
> > > of the procedure > new layer > new blending mode > twice! >< and
> in
> > my case
> > > the PSD image didn't change size. Started out at 284 megs and
> after 2
> > > additional adjustment layers with different blending curves on
> each
> > and the
> > > results is still 284 megs.
> > > Sorry, don't know what we're doing differently but something is
> > different.
> > > Alan
> > > _____
> > > From: DigitalBlackandWhiteThePrint@yahoogroups.com
> > > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> > zonepeter
> > > Sent: Friday, August 03, 2007 2:36 PM
> > > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > > Subject: [Digital BW] Layers and BLending Modes
> > > In Amadou Diallo's book, and other places, I have read that if
> you use
> > > an empty adjustment layer with a blending mode change, the file
> size
> > > will not grow. When I try to do this, my file size grows like
> with any
> > > other adjustment layer. I open a new adjustment layer (usually
> curve)
> > > and OK it without any changes made. At this point, the file size
> has
> > > grown. What am I doing wrong?
> > > Thanks,
> > > Peter
> > > [Non-text portions of this message have been removed]
