Spongeless carts problem.
2007-08-04 by hindibook
This may have been covered before but here goes: A friend gave me an Epson 1270 a couple of weeks ago and I decided to set it up with UT2 ink and spongeless cartridges. All went fine and I was getting great results with this ink but I stated to have random nozzles clogging. When I would do a cleaning cycle it would sometimes get worse, it was obvious I was getting air in the head. I followed the instruction on priming the carts from MIS which stated not to remove too much ink from the cart only about 1 cc. What I found out was there were small air pockets around the valve that I did not get out, I need to get some vacuumed on it and pull more ink through to get rid of the air (this took some doing). If you are a first time user of these spongeless cartridges do a very good job on priming or expect problems. Tim
