Dark skies and Dmax
Dark skies and Dmax
2007-08-06 by SteveZ
I need some advise on printing images with dark skies and/or skies that
have a distinct transition gradient from dark to lighter tones
Unlike most of you, I'm relatively new to digital b&W printing
and, as such, technically challenged when it comes to measuring dmax,
creating profiles, etc.
I'm using a 3800 with k3 inks with matte papers that include VFA, HPR
and MPR. For b&w I normally use the the ABW driver but even when using
the RGB driver/media profiles the results invariably are the same.
I've also made test prints with all of the above papers with similar
outcomes: solid black skies with no detail.
Without getting too technical,
can anybody shed some light?
Re: [Digital BW] Dark skies and Dmax
2007-08-06 by petegorsky@external.umass.edu
Steve - I'm sure you're going to get a lot of different and probably conflicting
advice on your
situation.  Part of the answer would depend on how involved you're willing to
get with the technical
end of things.  For example, without knowing more, it's hard to tell whether the
problem lies with
your file or with your printing approach.  If you don't have a good monitor that
is calibrated well, you
may have problems with the file you're trying to print that aren't going to be
visible.  On the other
hand, if you trust the monitor image, it's time to start experimenting with the
different settings
available to you with whatever driver you're going to use to make your prints,
whether as RGB or
Grayscale files.
If you provide more information about your approach, you'll get more specific
advice, but there is
ultimately nothing like trial and error to really learn this stuff!
Stephen Petegorsky
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, petegorsky@...
> advice on your
willing to
tell whether the
> problem lies with
monitor that
going to be
> different settings
your prints,
> whether as RGB or
> Grayscale files.
more specific
> Stephen Petegorsky
Stephen, yes, my monitor is calibrated, this issue occurs only on
prints with dark, featureless skies. Could this be a result of over
inking?
Steve - it could be the result of many things, and I'd suggest trying to isolate
the variables as you
try to solve the problem.  If you're using the Epson driver, for example, you
could try cutting back
on the percentage of inking in 10% increments to see if there is any difference.
How is the rest of the image rendered?  Is the overall lightness/darkness and
contrast good, or is
there tonal compression in other dark areas?
SP
2007-08-06 by BKPhoto@aol.com
Steve-
You've question leads to a core issue in printing on the OEM path. You have an excellent printer, inks, and you're working with excellent papers. And, while ABW is pretty nifty, it is part of the "black box" that is the print driver software. This means you are printing through a embedded profile locked in the box; this, combined with the fact that Epson print drivers habitually lay down too much ink, can easily result in loss of tonal definition. In your case, the inability to replicate image code values into print tonality accurately.
If you want to stay on the OEM path, there are two options you can explore. First, make adjustments in the Printer Color Management panel; try using Normal or Light in the Tone menu. You can also experiment with the other controls in this panel, but I'd suggest making small moves, printing, trying again, until you get something usable. If you do find something usable, be sure to save the settings through the Presets menu. You'll have to do this for each paper in turn. Sorry.
Also, you can experiment with the Color Density slider found in the Paper Configuration panel. Again, make small changes, print, try again.
What you'll be doing, essentially, is twiddling with the knobs and switches attached to the black box. While this will allow you to stay on the OEM path, it will never produce the accurate print that a properly ink limited, linearized, and profiled system is capable of. Understand, I'm not advocating that you stray off the path. You may be able to tweak your workflow enough to solve the problem. You'll certainly learn a lot about the behavior of the print driver this way.
Bill Kennedy
K2 Press
Austin, Texas
Author of "The Photographer's Guide to the Digital Darkroom", Allworth Press.
Sent: Mon, 6 Aug 2007 10:23 am
Subject: [Digital BW] Dark skies and Dmax
________________________________________________________________________
AOL now offers free email to everyone.  Find out more about what's free from AOL at AOL.com.
2007-08-06 by Michael King
Steve,
There are so many things here that could be wrong.
Here's my suggestion as to how you figure things out a bit more.
VFA + ABW is a great combo so I would start with that. You won't get a
better matte dmax than this combo.
If you have your image in Adobe RGB or Grey Gamma 2.2 and print with ABW set
to "normal" you will get a somewhat lighter image than you want but its
guaranteed not to bury your blacks. If it does then you have something wrong
with your printing settings.
If "normal" works I would now try, ABW set to "Dark" which should be about
right for an image in gamma 2.2
Beyond this you can get more sophisticated using a spectro and QTR Create
ICC
Also if you want to dive in deeper, Eric has a ton of info on this site
http://people.csail.mit.edu/ericchan/dp/Epson3800/
Good luck.
Mike
Re: Dark skies and Dmax
To my eye, the rest of the image looks fine. Now when you say cutting
back on % of ink in 10% increments, how does one do that?
trying to isolate
example, you
any difference.
> SP
Bill,
I do find that my 4800 ABW settings (linearity, inking etc.) for Epson
papers are great, Epson have clearly worked hard on this.
If you combine ABW+Epson Papers + QTR Create ICC you do have a very usable,
repeatable workflow that produces fantastic results on VFA and USFA.
I would agree that you have to work harder with non Epson papers that don't
hold as much ink, to make ABW work effectively, but its doable. I often find
that Textured Fine Art is the setting that works best for a lot of non-Epson
papers. It has a lighter ink load than other paper settings.
Mike
On 06/08/07, BKPhoto@... <BKPhoto@...> wrote:
> Steve-
> Bill Kennedy
> K2 Press
> Austin, Texas
> Press.
> From: SteveZ <blizzie12@... <blizzie12%40yahoo.com>>
> To: DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>
2007-08-06 by Alan Kearney
Bill,
I also find my 4800 ABW settings with Hahnemühle's German Etching 310
roll stock, using their custom profile and VFA paper settings (as per
Hahnemühle instructions) give me terrific results. Printed "Dark" the
images just pop off the paper. IMHO :)
Alan
On Aug 6, 2007, at 8:57 AM, Michael King wrote:
> Bill,
> usable,
> that don't
> often find
> non-Epson
> Mike
> > Steve-
> path. You
> excellent papers.
> that is the
> embedded
> Epson print
> loss of tonal
> values into
> panel; try
> with the
> printing,
> something
> You'll have
> the Paper
> stay on the
> properly ink
> Understand, I'm not
> your
> lot about the
> > Bill Kennedy
> > K2 Press
> > Austin, Texas
> Allworth
> > Press.
> To:DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteTh
> skies that
> dmax,
> HPR
> using
> free
Re: [Digital BW] Re: Dark skies and Dmax
Quoting SteveZ <blizzie12@...>:
When you're in the Epson print dialogue box, go to the box beneath "Presets" and
select "Ink
Configuration". In that box there is a slider that allows you to adjust "Color
Density".  You can
decrease the amount as a percentage.
SP
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, BKPhoto@...
wrote:
>  Steve-
accurately.
turn. Sorry.
again.
> Bill Kennedy
> K2 Press
> Austin, Texas
Allworth Press.
> Thanks, Bill, this helps!
> From: SteveZ <blizzie12@...>
that
dmax,
HPR
using
similar
__
