Touch-up pen for matte paper flakes? Is there such a thing?
2007-08-07 by sagaface
Like a bozo, I didn't take the time to wipe down the paper before printing, and now I have glaring white spots where the paper has flaked....damn HPR! Anyone have suggestions for a way to touch these areas up? thanks, Sarah
2007-08-07 by Mark Savoia
Open your maintenance tank, use some "wet" ink from there, take a very small brush, 00000, and test on a waste piece of HPR until you have the matched density, then spot it like a silver print. Good to keep some waste ink around in a film can for future uses. Mark
On Aug 7, 2007, at 2:31 PM, sagaface wrote: > Like a bozo, I didn't take the time to wipe down the paper before > printing, and now I have > glaring white spots where the paper has flaked....damn HPR! > > Anyone have suggestions for a way to touch these areas up? > > thanks, > Sarah
2007-08-07 by Tyler Boley
I use Spotpens, but Mark's suggestion is brilliant and deceptively obvious... Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" <sagaface@...> wrote: > > Like a bozo, I didn't take the time to wipe down the paper before printing, and now I have
> glaring white spots where the paper has flaked....damn HPR! > > Anyone have suggestions for a way to touch these areas up? > > thanks, > Sarah >
2007-08-07 by john dean
I use Windsor Newton watercolor pigments custom blended and a good red sable #1 brush. Build it up gradually, in very light layers, and use tiny dots, not big blobs of wet ink. Mark does have the best idea for black and white, and much color, use some of that ink Epson forces us to waste. Which reminds me, if I don't empty that waste tank I'm going to have plenty on my floor next week to mop up. I always let it go too far. john --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote:
> > I use Spotpens, but Mark's suggestion is brilliant and deceptively > obvious... > > Tyler > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface" > <sagaface@> wrote: > > > > Like a bozo, I didn't take the time to wipe down the paper before > printing, and now I have > > glaring white spots where the paper has flaked....damn HPR! > > > > Anyone have suggestions for a way to touch these areas up? > > > > thanks, > > Sarah > > >
2007-08-07 by Andrew Darlow
Hi Sarah: Here's a quick way to deal with this issue. You can cut and paste the areas that have spots onto a new 8.5x11 sheet and stick a few pieces of clear cellophane tape in the areas where the printer will apply the ink. I would not use too many pieces of tape (maybe 3-5 spaced out on the sheet). You can also get a full sheet the same size as your print and spot apply the cellophane tape, print and apply from there, but that seems like a waste. After making a print (using the same settings as your original), just dab on the ink that is sitting on the clear plastic with a small brush like an artist uses a palette. I think that you'll find the color match to be much better that way. Although the tape idea is one that I came up with, I learned this general touch up tip from someone on one of the fine Yahoo forums (maybe this one) a few years back. He or she used a plastic sheet to print on (such the uncoated back of a piece of inkjet-compatible film). Hope that works for you. All the best, Andrew Darlow --------------------------------------------------- Andrew Darlow Editor, The Imaging Buffet http://www.imagingbuffet.com On Aug 7, 2007, at 2:31 PM, sagaface wrote: > Like a bozo, I didn't take the time to wipe down the paper before > printing, and now I have > glaring white spots where the paper has flaked....damn HPR! > > Anyone have suggestions for a way to touch these areas up? > > thanks, > Sarah > > > > [Non-text portions of this message have been removed]
2007-08-07 by Sarah Renkes
I don't know what I'd do w/o this forum....it's just great to get a variety of suggestions to any given query....thanks all of you. Given the simplicity, the fact I printed using Eboni ink only and the number of prints to correct...I'm going to try your waste ink approach, Mark. I think you might have just saved me a bucket of money...I'm crossing my fingers I won't have to re-print. HPR 13X19 is expensive! Learned my lesson on the wipe-down, that's for sure. Yikes. Thanks again to all!!! Sarah --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Andrew Darlow <ad@...> wrote:
> > Hi Sarah: > > Here's a quick way to deal with this issue. You can cut and paste the > areas that have spots onto a new 8.5x11 sheet and stick a few pieces > of clear cellophane tape in the areas where the printer will apply > the ink. I would not use too many pieces of tape (maybe 3-5 spaced > out on the sheet). > > You can also get a full sheet the same size as your print and spot > apply the cellophane tape, print and apply from there, but that seems > like a waste. > > After making a print (using the same settings as your original), just > dab on the ink that is sitting on the clear plastic with a small > brush like an artist uses a palette. I think that you'll find the > color match to be much better that way. > > Although the tape idea is one that I came up with, I learned this > general touch up tip from someone on one of the fine Yahoo forums > (maybe this one) a few years back. He or she used a plastic sheet to > print on (such the uncoated back of a piece of inkjet-compatible film). > > Hope that works for you. > > All the best, > > Andrew Darlow > > > --------------------------------------------------- > Andrew Darlow > Editor, The Imaging Buffet > http://www.imagingbuffet.com > > > > On Aug 7, 2007, at 2:31 PM, sagaface wrote: > > > Like a bozo, I didn't take the time to wipe down the paper before > > printing, and now I have > > glaring white spots where the paper has flaked....damn HPR! > > > > Anyone have suggestions for a way to touch these areas up? > > > > thanks, > > Sarah > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] >
John, What, no waste bypass tube installed? I have not looked in my maintenance tank in over 2 1/2 years. I wonder what is in there? :)Mark On Aug 7, 2007, at 4:05 PM, john dean wrote: > Which reminds me, if I don't empty that waste tank I'm going > to have plenty on my floor next week to mop up. [Non-text portions of this message have been removed]
2007-08-07 by Roger Sopher
sagaface wrote: > > Like a bozo, I didn't take the time to wipe down the paper before > printing, and now I have > glaring white spots where the paper has flaked....damn HPR! > > Anyone have suggestions for a way to touch these areas up? > > thanks, > Sarah > > Hi Sarah, An easy way is to print a step wedge on a piece of glossy paper. The ink doesn't bond tightly and can be lifted with a damp spotting brush and then applied to the areas of the print that need spotting. The main advantage of this approach is that it gives you 21 steps of gray so matching the flaked area is fairly easy. Also, you can put the wedge aside when you are finished and use it again when needed. It's a bit like using a ceramic dish with the old spot tone dyes without the manual mixing. Roger [Non-text portions of this message have been removed]
I know. I keep forgetting your bottle and tube approach. I need to do that with all my printers so I never have to think about it again. Can you tell me why Epson didn't think of that? --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> > John, > What, no waste bypass tube installed? I have not looked in my > maintenance tank in over 2 1/2 years. I wonder what is in there? > :)Mark > > > On Aug 7, 2007, at 4:05 PM, john dean wrote: > > > Which reminds me, if I don't empty that waste tank I'm going > > to have plenty on my floor next week to mop up. > > > > [Non-text portions of this message have been removed] >
They did (sort of), an Epson tech told me how to do it years ago starting with the 9000. Mark
On Aug 7, 2007, at 5:25 PM, john dean wrote: > I know. I keep forgetting your bottle and tube approach. I need to do > that with all my printers so I never have to think about it again. Can > you tell me why Epson didn't think of that? >
2007-08-08 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john dean" <deanwork2003@...> wrote: > > I know. I keep forgetting your bottle and tube approach. I need to do > that with all my printers so I never have to think about it again. Can > you tell me why Epson didn't think of that? > > I'm sure they did, and some bean counter suggested that they could get MORE MONEY with the tanks. Why do you think they have the chips on them.
2007-08-08 by jimrohan2002
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote: > > John, > What, no waste bypass tube installed? I have not looked in my > maintenance tank in over 2 1/2 years. I wonder what is in there? > :)Mark > > > There are some things that are better left unknown. What's inside your maintenance tank after two and a half years would be one of those things. Jim Rohan
2007-08-08 by Tyler Boley
Mark, for the chipped tank printers do you just leave a tank in and reset the chip when prompted? Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> > They did (sort of), an Epson tech told me how to do it years ago > starting with the 9000. > Mark > > On Aug 7, 2007, at 5:25 PM, john dean wrote: > > > I know. I keep forgetting your bottle and tube approach. I need to do > > that with all my printers so I never have to think about it again. Can > > you tell me why Epson didn't think of that? > > >
2007-08-08 by Mark Savoia
Yes sir. I have lost track how many times I have done the resets over the years. Mark
On Aug 8, 2007, at 10:39 AM, Tyler Boley wrote: > Mark, for the chipped tank printers do you just leave a tank in and > reset the chip when > prompted? > Tyler > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia > <mark@...> wrote: >> >> They did (sort of), an Epson tech told me how to do it years ago >> starting with the 9000. >> Mark >> >> On Aug 7, 2007, at 5:25 PM, john dean wrote: >> >>> I know. I keep forgetting your bottle and tube approach. I need >>> to do >>> that with all my printers so I never have to think about it >>> again. Can >>> you tell me why Epson didn't think of that? >>> >> > > > > > Please visit the Group Homepage to check the Files, and other > resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you > wish to unsubscribe, please edit your Membership preferences by > visiting this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages > to keep them short. > - Good manners are required at all time. No personal attacks or > flames. Hostile, aggressive or argumentative users may be removed > from the membership without notice. > - Keep your posts and threads related to the group topic of digital > B&W printing. Users who persistently make off-topic posts may be > removed from the membership. > - By posting on this forum you agree to abide by the group rules > and guidelines, and to abide by the actions and decisions of the > group Owner and Moderators. See “Group Topic, Rules and Guidelines” > in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER > INTANGIBLE LOSSES (EVEN IF THE “OWNER” AND “MODERATORS” OF DIGITAL > BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF > SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE > THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO > OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR > CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO > GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > Yahoo! Groups Links > > > > >
