Printing for different viewing light levels
2007-08-09 by john794552
On Windows XP and using CS3, I print toned monochromes on an Epson
2400. Both monitor and printer/paper combination are calibrated. I use
an LCD monitor, and the printer output when viewed under a bright
white bulb corresponds well to the appearance on the monitor. However
in lower viewing light levels as, say, a camera club venue, shadow
details are more difficult to discern. This more of a problem with
images that are printed more darkly, which, in my case, is quite a
high proportion.
I have tried applying a brightening levels adjustment, but, having
worked hard to produce subtle shadow detail, I feel this is a very
blunt tool for solving my problem.
Have others experienced this problem? If so, how have you approached
the problem?
Many thanks
John
Re: [Digital BW] Printing for different viewing light levels
2007-08-09 by Stephen Petegorsky
John ­ I have found that for critical purposes, I need to often have two
sets of prints.  One is made for portfolio use where I will be showing the
prints bare (no glass/frame) and another for when the prints will be hung
under glass.  This is for the same reason you mentioned; the dark values
lose some clarity when they are viewed under lower light than I¹ve used for
printing/correcting.
Unfortunately, there is no standard lux level or lighting arrangement used
from space to space.  Museums these days typically use lower light levels
than they used to for issues of conservation.   Unless you were able to go
into a space in which your prints will be shown and compare a couple of
prints under glass to see which look best, you will probably just be
guessing at the adjustment you¹ll need to make to compensate for the lower
light,
If you are going to make an adjustment, you could do it in a number of ways.
You could make a PSD copy of the file that prints correctly, and create an
adjustment layer for levels (you could bump up the output level slider below
the histogram to open up the dark end), for curves, etc., and make prints at
a few different settings for comparison.  Be sure to mark each print as you
make it so that you don¹t lose track of the changes you¹ve made.
Stephen
2007-08-09 by CDTobie@aol.com
high proportion.
the problem?
There are two tools typically used by PrintFIX PRO owners for this
issue. One is the Viewing Light Level slider, which adjusts the print
density globally. The other is the Shadow Detail slider, which targets
just the shadow details. Nothing in either that can't be accomplished,
this just builds profile versions for making your selected adjustment
to any print.
C. David Tobie
Product Technology Manager
ColorVision, Inc.
CDTobie@...
www.colorvision.com
________________________________________________________________________
AOL now offers free email to everyone.  Find out more about what's free
from AOL at AOL.com.
RE: [Digital BW] Printing for different viewing light levels
2007-08-09 by Eric Neilsen
Have you taken a light meter with you to the camera club and measured the
light? I presume that they know what one is right? And that it would be a
great idea to standardize the viewing conditions so that members can print
to that standard. Or short of that you can attach a "conditions for proper
viewing" sheet to your prints. Some one needs to be proactive in that
situation. I gave a presentation to a local camera some time back. I was
running late and could not make it back to my studio due to traffic to get
my prints and make the  meeting on time. I was also planning on a digital
slide show. They did not have a calibrated set up. Camera clubs can talk
photography all day and night but unless they provide a good environment to
view real work, what does it really matter?
If you participate in a club, it would only help every one to use a known
standard light set up.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
john794552
Sent: Thursday, August 09, 2007 2:50 AM
Subject: [Digital BW] Printing for different viewing light levels
high proportion.
the problem?
Many thanks
John
Re: Printing for different viewing light levels
2007-08-09 by David
I find that my prints are usually much darker on paper than on my LCD
screen. To get around this, I turn the brightness on the LCD way down
after its been calibrated. The main drawback is there is a bit of a
color/tone shift from viewing the calibrated monitor at full brightness
(my calibration software will only work on a fairly bright screen.)
Once I have the prints where I like them, I find they work for most
situations--and I don't have to do two different versions. Of course,
if its too dark, even a bright print will not look good. I'd say print
for the light conditions you'll most likely be viewing in.
David.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "john794552"
<jwillyfontana@...> wrote:
> I use
> in lower viewing light, shadow
> high proportion.
> the problem?
Thanks for the helpful replies. Might try your idea, David, of
turning screen brightness down.I would worry about the effects on
the highlights of using a global, say, levels change.
Another approach I have been working on is to convert my image layer
to a Smart Object, and applying a Shadows/Highlight filter to the
smart object layer. This gives a non-destructive
Shadows/Highlight 'adjustment layer' that can be modified to and fro
until the right degree of lightening for the viewing conditions can
be worked out. I guess if I then saved these settings as an .SHH
file, I could apply them to all future prints on this paper.
use
However
> high proportion.
approached
> the problem?
> Many thanks
> John
Eric,
The idea of trying to measure light levels in the viewing scenario is
novel and interesting. I am not sure how practical for the majority of
camera club members it might be. Certainly would seem to be a great
idea for visiting speakers. I remember at my recent Associate of Royal
Photographic Society distinction attempt, that the EV viewing value
was quoted in the information supplied.
John
