change HTML to acv in Roark's curves
2007-09-06 by lovelipp
I followed the directions on Paul Roark's site, but can't get the file
extension to change. I use MIS UT7 inks in a 7600. This happened before
a long time ago, and I can't remember how I made it change. The curves
are not working. Please help.
Arlene
arlenelove3@...2007-09-06 by dizpark
Arlene! This is how I got it to work on my Windows XPP machine. Right click on the link, save target as, and then in the dialog box change two things - in filename box overwrite .html extension with .acv - in Save as type box, change to All files. Good luck. Didzis > > I followed the directions on Paul Roark's site, but can't get the file > extension to change. I use MIS UT7 inks in a 7600. This happened before > a long time ago, and I can't remember how I made it change. The curves
> are not working. Please help. > Thanks, > Arlene > arlenelove3@... >
2007-09-07 by Paul Roark
Hi Arlene, With the new ISP, the extensions should not need changing. My old UT7 - 7600 Readme file, however, had the old website links in it. Try http://www.paulroark.com/BW-Info/UT7-7600-curves.html and download the files in the normal manner - right click and then "Save As." On my XP machine the *.acv extensions are there. If there is some other problem let me know. Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of lovelipp Sent: Thursday, September 06, 2007 1:09 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] change HTML to acv in Roark's curves I followed the directions on Paul Roark's site, but can't get the file extension to change. I use MIS UT7 inks in a 7600. This happened before a long time ago, and I can't remember how I made it change. The curves are not working. Please help. Thanks, Arlene arlenelove3@ <mailto:arlenelove3%40aol.com> aol.com [Non-text portions of this message have been removed]
2007-09-07 by Vincent Orlando
Paul, will these work on a Mac Vinny www.wulfsden.com --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > Hi Arlene, > > > > With the new ISP, the extensions should not need changing. My old UT7 - > 7600 Readme file, however, had the old website links in it. Try > http://www.paulroark.com/BW-Info/UT7-7600-curves.html and download the files > in the normal manner - right click and then "Save As." On my XP machine the > *.acv extensions are there. > > > > If there is some other problem let me know. > > > > Paul > > www.PaulRoark.com <http://www.paulroark.com/> > > > > > > _____ > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of lovelipp
> Sent: Thursday, September 06, 2007 1:09 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] change HTML to acv in Roark's curves > > > > I followed the directions on Paul Roark's site, but can't get the file > extension to change. I use MIS UT7 inks in a 7600. This happened before > a long time ago, and I can't remember how I made it change. The curves > are not working. Please help. > Thanks, > Arlene > arlenelove3@ <mailto:arlenelove3%40aol.com> aol.com > > > > > > [Non-text portions of this message have been removed] >
2007-09-07 by arlenelove3@aol.com
As always, Paul came through with the answer. After two days of anguish, it
took two minutes to fix the problem.
Arlene
arlenelove3@...
************************************** Get a sneak peek of the all-new AOL at
http://discover.aol.com/memed/aolcom30tour
[Non-text portions of this message have been removed]2007-09-07 by Paul Roark
The *.acv curves always appeared to work fine on Macs as long as they were ones where the driver was set to "No Color Adjustment." (I'd made some, mostly early ones, that used "Color Controls." This setting appears to be different on the different platforms.) Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Vincent Orlando Sent: Friday, September 07, 2007 3:06 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] change HTML to acv in Roark's curves Paul, will these work on a Mac Vinny www.wulfsden.com --- In DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > Hi Arlene, > > > > With the new ISP, the extensions should not need changing. My old UT7 - > 7600 Readme file, however, had the old website links in it. Try > http://www.paulroar <http://www.paulroark.com/BW-Info/UT7-7600-curves.html> k.com/BW-Info/UT7-7600-curves.html and download the files > in the normal manner - right click and then "Save As." On my XP machine the > *.acv extensions are there. > > > > If there is some other problem let me know. > > > > Paul > > www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/> > > > > > > _____ > > From: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com > [mailto:DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com] On Behalf Of lovelipp > Sent: Thursday, September 06, 2007 1:09 PM > To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com > Subject: [Digital BW] change HTML to acv in Roark's curves > > > > I followed the directions on Paul Roark's site, but can't get the file > extension to change. I use MIS UT7 inks in a 7600. This happened before > a long time ago, and I can't remember how I made it change. The curves > are not working. Please help. > Thanks, > Arlene > arlenelove3@ <mailto:arlenelove3%40aol.com> aol.com > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]
