Repurposing QTR Profiles
2007-11-05 by Louis Dina
I'm sure people have tried this, perhaps succesfully and I thought I'd
ask before I spend a lot of time on it.  No sense reinventing the wheel.
I have some great QTR profiles for my 2200 using UC color inks.  I want
to build the same sets of profiles for my 4000 using the same inks, but
of course, the 4000 has different ink limits.  The profiles on both
printers will be based on the same printing parameters (2880 dpi,
unidirectional, ordered).  I was wondering if I can simply open the
2200 profile, rename it for my 4000, and simply reset the total ink
limit and relinearize for the 4000.  I am assuning that the
relationships between the inks would be the same percentage wise from
the 2200 to the 4000.  Will this method generate good profiles, or is
it necessary to start from scratch to get excellent profiles?
If such a method does work, how do people do it?  I was thinking of
determining the Black ink limit conventionally, plugging the new limit
into the repurposed profile, removing the linearization information,
and reprinting a target for final linearization.
Thoughts, cautions, results?
Thanks, as always.
Lou Dina
RE: [Digital BW] Repurposing QTR Profiles
2007-11-05 by Paul Roark
Hi Lou,
>I want to build the same sets of profiles for my 4000 using the
>same inks, but of course, the 4000 has different ink limits.
>The profiles on both printers will be based on the same printing
>parameters (2880 dpi, unidirectional, ordered).
Go into the files and change or remove the printer name inside the file.  I
use Notepad to open the files.
> and simply reset the total ink limit and relinearize for the 4000.
>I am assuming that the relationships between the inks would be the
>same percentage wise from the 2200 to the 4000.
Yes, my experience is that profiles are much more portable with QTR than
with the Epson driver.
> I was thinking of determining the Black ink limit conventionally,
> plugging the new limit into the repurposed profile, removing
>the linearization information, and reprinting a target for
That sounds like an efficient way to do it.  Let us know how it works.
Re: Repurposing QTR Profiles
2007-11-06 by Roy Harrington
Hi Lou,
Moving profiles from the 2200 to 4000 with the same UC inks should be
very doable.   As you say just copy the files over from the 2200 folder to
the 4000 folder.   The main difference will be the ink limits.  If your profiles
are for 2880dpi then they just use single smallest dropsize.  2200 is spec'd
at 4pl and the 4000 at 3.5pl -- then figure 4/3.5 = 1.143 so just multiply all
the ink limits by 1.143 and you ought to be very close.  You may want minor
tweaks.  Then re-linearize and I bet you'll be quite satisfied.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina" <lou@...>
> Thanks, as always.
> Lou Dina
Re: [Digital BW] Repurposing QTR Profiles
2007-11-06 by Louis Dina
Thanks, Paul.
I kind of thought it might work like that.  Here is some feedback on
my first attempt.
I created a new 'neutral' profile for my 4000 using a previously
created 2200 profile.  I used 2880 dpi, unidirectional printing, and
the Ordered algorithm for both.  This particular profile uses MISPro
inks (UC clones) PK, LK, LC and LM, so it may not be of interest to
people who wish to avoid colored inks.
I printed your new 21 step grayscale using ONLY the PK ink, and QTR
Plot List coordinates of 0,0 and 100,100, which gives linear (not
linearized) output.  Linearization data was removed from this test
profile and ink limit was set to 100.  (I could also have used the
Calibration target, which prints all 7 inks, but went this route
instead since I only cared about the PK ink for setting Dmax).  The
ramp showed a Dmax at 70%.
So, I plugged 70 into the default ink limit of my original 2200
profile, saved it as a 4000 profile in my 4000 folder, and printed
the same grayscale with it.  The profile looked great and was pretty
neutral, but I had set the ink limit a bit too high (as I often do
trying to get the absolute best Dmax) and the last two patches read
almost exactly the same.  Too much ink.  So, I lowered the ink limit
to 60% and set the black boost to 70% for a little kick at the dark
end and got a really good test print, which I then read and
linearized.
I made a print with it and it looks great.
So, this procedure worked fine for repurposing a 2200 profile to my
4000 using the same inkset.  This will save a LOT of time since I
already have good profiles for my 2200 on a number of papers.
Thanks for the help, as always.
Lou
<paul.roark@...> wrote:
> Hi Lou,
file.  I
4000.
than
works.
> Paul
> www.PaulRoark.com
Thanks, Roy. I answered Paul just before your message popped up.
Interesting about the 4/3.5 pl relationship.  I never thought about
it, but it makes sense.  I'll compare my two profiles to see how that
relationship held up.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
<roy@...> wrote:
> Hi Lou,
be
folder to
your profiles
is spec'd
multiply all
want minor
> Roy
<lou@>
thought I'd
wheel.
I want
inks, but
both
ink
from
or is
of
limit
information,
> > Thanks, as always.
> > Lou Dina
