Epson 2200 ink disfunction
2007-12-16 by Myron Gochnauer
Do any of you have any idea why an Epson 2200 would very suddenly (but
consistenly, now) almost completely stop printing one or more "colors"
part way through something like an 11x17 print?
I can begin with a perfect nozzle check and full cartridges, start
printing something that requires a fairly large about of ink, and have
one or more inks essentially stop printing half way across the page.
Grrrrr.
A nozzle check immediately after this happens looks like a disaster
for all of the colors. A few hours later, usually after unsuccessfully
running a couple cleaning cycles, it will be back to good nozzle checks.
It is *not* always the same cartridge.
It *acts* as though some kind of ink pump cannot keep up, or there is
a leak in a line somewhere...  but I don't know how those Epson heads
"suck" ink from the cartridges and "blow" it onto the paper.
Have any of you torn one of these things far enough apart to know
where the "impotence" might be found?
I would probably just stop using the printer, but my new R1800 is
totally useless for printing on canvas (something the 2200 does quite
easily, I might add).
Thanks.
Myron
Re: [Digital BW] Epson 2200 ink disfunction
2007-12-17 by Tony Sleep
All too familiar here with a 1290 (using G4 pigments in a CIS). It is due
to partially blocked microfilters in the head. Under the feed spigots that
penetrate the cart. seals, there are small filters that are present to
prevent particles reaching the heads. Over time they block and become
unable to feed sufficient ink under continuous high demand. The filters
are not replaceable, they are integral to the head.
You can attempt to clean the filters using a syringe with tube that fits
over the spigot. A cleaning solution of Windex/Windowlene clear, distilled
water and isopropanol is used with a little push-pull action of the syringe.
However I found this completely useless and eventually gave up and
replaced the head. On a 1290 this is an easy 15 minute DIY proposition,
requiring just a couple of screwdrivers, a bit of common sense and no
special alignment tools or software, and it cost half what Epson charge.
Epson do also change the waste pad and zero its counter, and wipe the
inside with an oily rag and give a warranty, of course. But that was no
use to me anyway because I was using a CIS with Generations pigment inks.
I think the 2100/2200 are pretty similar designs to the 1290, so this
might be viable for you - but check no engineer alignment s/w is needed,
as it is on some models.
In UK a new head can be got from
Unicomp Ltd
01732 781400
Bourne Estate
Borough Green  TN15 8DG
Intriguingly, the new head was far better behaved than the original, which
had tended to clog quite often. The new one never did, which makes me
think there are some mfr. quality/consistency issues there. However 9m
later the microfilter on the Y channel clogged up again.
I'm now finished with 1290's and won't be buying any more Epson 'amateur'
printers.
Tony Sleep
http://tonysleep.co.uk
2007-12-18 by Brubaker family
Myron,
You need to head on over to the Yahoo Epson printer
group and get an Epson cleaning manual from Art
Entlich.  You have to privately email him a request
for the manual.  He posts pretty frequently and at
least once a week or so posts the email address to
request the manual.
From seeing Art's previous posts I wonder if the
suction tube on your printer has come off of the pump
end or the head parking station end.  The pump is what
applies suction to the head during a nozzle cleaning,
and if it isn't applying the suction adequately the
cleaning won't be thorough.  Also, if it were my
printer I would make some cleaning carts for it with
some empty Epson carts using Art's Windex/alcohol
cleaning fluid.
Mike Brubaker
> very suddenly (but
> cartridges, start
> across the page.
> Grrrrr.
> like a disaster
> good nozzle checks.
> those Epson heads
> the paper.
> apart to know
> new R1800 is
> the 2200 does quite
> Thanks.
> Myron
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Here's Art's email address:
e-printerhelp( at)mvps(dot) org
(at) = @
(dot) = .
He just posted it again today.
> very suddenly (but
> cartridges, start
> across the page.
> Grrrrr.
> like a disaster
> good nozzle checks.
> those Epson heads
> the paper.
> apart to know
> new R1800 is
> the 2200 does quite
> Thanks.
> Myron
RE: [Digital BW] Epson 2200 ink disfunction
2007-12-18 by Eric Neilsen
Don't know if this is your problem but it jumped off the page at me. . I'd
use my R1800 but it doesn't work on CANVAS.
Lint, dust, fiber, etc may be clogging you heads. I'd buy into your heads
being messed up IF it happens all the time with bigger prints or ink lat
down but if it only happens on CANVAS, then it is your choice of canvas or
canvas in general. I don't use a 2200 enough to be able to tell you that.
I do, however, have limited experience cleaning up a very clogged unit. I
was given one and ran a set of clean cart and the printer is working fine.
Eric
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Tony
Sleep
Sent: Monday, December 17, 2007 5:41 AM
Subject: Re: [Digital BW] Epson 2200 ink disfunction
