greenish cast in shadows in K4-ABW prints
2008-01-18 by daniel
I've been printing with K3 inks on an Epson 2400 in ABW mode, and have been very pleased with the results on glossy paper. I decided to give MIS K4 inks a try, both because of the reduced cost, and because of the hope that I would get better results on matte papers -- in particular, a flatter look in the black and eventually (when I follow Paul Roark's advice and switch the yellow for a light carbon) better neutrality. But my first experiments have not been encouraging. I get a very slight but unpleasant greenish-blue cast in the shadows. I suspect it's noticeable only because the lighter tones are so warm. I'm surprised by this because I thought that MIS Eboni would be _warmer_ than Epson MK, so I would expect that if ABW mixes in some color to cool off the ink in the shadows, it would result in less cooling in the K4 case. When I print a 21-step ramp, the color cast is evident in the 85% patch, with the A* value dipping below the axis to about -0.5. Both A* and B* are positive elsewhere with reasonable values (between 0 and 2). These readings are on EEM; Photo Rag shows a similar effect. I'm wondering if I have a bad batch of Eboni. When I paint some of the ink straight onto paper with a cotton bud and take readings, I get A*=0.7 and B*=1.6, which seems reasonable. When I print in black only mode, the print doesn't look very warm at all, which is surprising. (But maybe selecting "black" mode in the driver doesn't actually restrict the ink to black?) One other piece of information: I still have some of the original K3 cartridges in: M and LM, following Roark's advice that they are better magentas than MIS's, and C. Any advice would be very welcome... --Daniel
