Paper Selection for Scanning
2008-02-14 by Eugene Ostreicher
My experience with scanning B&W negatives has not been favorable. I think that I will have to go back into my darkroom and print the photographs that I want to convert and then scan the prints to a digital format. Would appreciate any suggestions regarding paper type and size, contrast levels, and scanner settings. I have just purchased a 2400 and intend to work with an 11X14 print size.
2008-02-15 by Photo Studio
Eugene, I have just had the opposite problem and now going back the other way. In terms of scanning my b/w prints they just seem to be much dirtier with dust spots etc. Than my negatives and I find it easier to clean the dusty negs more than the prints. I also seem to get more detail with the negs. Maybe I will learn something from this post as well in terms of paper etc. It may require something different than I have been doing which is trying to scan on the Agfa Classic. Paul
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Eugene Ostreicher Sent: Thursday, February 14, 2008 11:25 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Paper Selection for Scanning My experience with scanning B&W negatives has not been favorable. I think that I will have to go back into my darkroom and print the photographs that I want to convert and then scan the prints to a digital format. Would appreciate any suggestions regarding paper type and size, contrast levels, and scanner settings. I have just purchased a 2400 and intend to work with an 11X14 print size. [Non-text portions of this message have been removed]
2008-02-15 by Eric Neilsen
Paul and Eugene, I have had great success with both. My first scans of my images were done back in the mid 90"s and it was printed on Agfa Multi Contrast Semi matte. I have also had great scans from both Imacon, drum and from my Nikon 9000. Dust on a flatbed scan can be minimized by good house work. High static conditions can lead to lots of dust. I am more concerned with dynamic range and sharpness way before I worry about a little dust. Focus is right there too. But dust is really not the problem. If you both describe a little more in depth your issues with your scans, I am sure I or some one else here will switch the answer on. Besides the dust what are we talking about? Eric Neilsen Photography 4101 Commerce Street Suite 9 Dallas, TX 75226 http://e.neilsen.home.att.net http://ericneilsenphotography.com Skype ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Photo Studio Sent: Thursday, February 14, 2008 6:42 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Paper Selection for Scanning Eugene, I have just had the opposite problem and now going back the other way. In terms of scanning my b/w prints they just seem to be much dirtier with dust spots etc. Than my negatives and I find it easier to clean the dusty negs more than the prints. I also seem to get more detail with the negs. Maybe I will learn something from this post as well in terms of paper etc. It may require something different than I have been doing which is trying to scan on the Agfa Classic. Paul -----Original Message----- From: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com [mailto:DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com] On Behalf Of Eugene Ostreicher Sent: Thursday, February 14, 2008 11:25 AM To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com Subject: [Digital BW] Paper Selection for Scanning My experience with scanning B&W negatives has not been favorable. I think that I will have to go back into my darkroom and print the photographs that I want to convert and then scan the prints to a digital format. Would appreciate any suggestions regarding paper type and size, contrast levels, and scanner settings. I have just purchased a 2400 and intend to work with an 11X14 print size. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2008-02-15 by Tony Sleep
On 14/02/2008 Eugene Ostreicher wrote: > My experience with scanning B&W negatives has not been favorable You are either using a poor scanner and/or need to refine your technique. A decent filmscanner and effective workflow will enable superior images from negatives that are near impossible to print in the darkroom, or will enable more complex or subtle realisation of decent negs as you have so much more control. It also gives an opportunity to rescue older negs that are now deteriorating. This won't apply if you are just wanting adequate electronic versions, but if you want the best quality possible I can't recommend scanning prints over negs, it's an extra generation and a lost opportunity. I had 20 years experience of almost daily darkroom printing behind me, so was pretty good at it. I too scanned prints initially but eventually realised the shortcomings and had to start again from negatives. -- Regards Tony Sleep http://tonysleep.co.uk
2008-02-15 by djon43
Excellence of B&W neg scanning is a matter of acquired skills and standard technology. Your only inexpensive film scanner options are Nikons. You should expect far better results than darkroom printing...sharper, more tonality. One advantage to scanning prints is that you can use Photoshop's Dust & Scratch Filter with less risk of detail softening than if you used it with a film scan (it works well with film scans too, if you use it lightly). It's adjustable, with previews, so you can accurately see the anticipated effect on the scan... --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eugene Ostreicher" <zetap@...> wrote:
> > My experience with scanning B&W negatives has not been favorable. I > think that I will have to go back into my darkroom and print the > photographs that I want to convert and then scan the prints to a > digital format. Would appreciate any suggestions regarding paper type > and size, contrast levels, and scanner settings. I have just purchased > a 2400 and intend to work with an 11X14 print size. >
2008-02-16 by TFielder
I am having problems with bronzing of the black areas on glossy paper using MIS inks on the Epson 220. I have read that the bronzing on glossy paper is a universal problem. Is that true especially for the Epson 220?? (BTW, I am using Paul's ICC profile.) I also have the Eboni black installed and I also understand that Photo Black is for glossy papers. Could that be the problem? The bronzing has occurred on 4 different glossy papers. The mat paper on the other hand looks great. Many thanks. Tom
2008-02-16 by Roger
I use the UTR2 inkset with the R220. Be sure to use the PK ink not Eboni (MK). I don't find bronzing very noticable at all with this inkset. There's a bit on Epson Premium Semigloss, but very little on other papers. You might try a different paper- my recent find is Harmon FB Baryta AL which looks great and has incredibly deep blacks. Use UPGPP Photo RPM and check super microweave. Roger --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "TFielder" <tfielder@...> wrote: > > I am having problems with bronzing of the black areas on glossy paper > using MIS inks on the Epson 220. I have read that the bronzing on > glossy paper is a universal problem. Is that true Eespecially for > the Epson 220?? (BTW, I am using Paul's ICC profile.) > > I also have the Eboni black installed and I also understand that Photo > Black is for glossy papers. Could that be the problem? The bronzing > has occurred on 4 different glossy papers. The mat paper on the other
> hand looks great. > > Many thanks. > > Tom >
