B9180 vs Piezography
2008-03-03 by warinstephan
I had the opportunity to dedicate a SP1290 to BW.
I finally ordered a neutral K6 set of piezography inks with a CIS.
Inkjetmall sent me a Lyson CIS. Not specific problem to prime the
system, excepted that I found the equipment quite "dusty", scaring if
you think of this dust going in the printhead! (hopefully there are
filters in the ink tank and in the fake cartridges)
I compared SP1290 K6 and B9180 on HPR paper.
I'm disappointed by the smaller Dmax of the piezography inks.
I'm also disappointed by the performances of the SP1290:
- slight banding in midtones (despite a perfect nozzle check and same
ink level in the CIS - half the bottle)
- for small prints, (5x7"), banding at the beginning and the end of
the print (not present on large prints)
- huge banding at black-only printing
- nozzle check compulsory before each print
- frequent nozzle cleaning cycles
- difficulties to grip a heavy paper (photorag 308 in this case)
I also noticed the black ink dribbling (deterioration of the finest
details), I'm not abble to tell if this is because of the ink or the
printer.
If I add to this all the advantages of the B9180: always ready to
print, no banding, no nozzle check, no missed print, no gripping ich
with the special media tray, easy possibility to tone a print... the
Epson is going directly to the dustbin! The inkjet printing
technology made huge improvements during 4 years, between a SP1290
and B9180!
I guess the newer Epson (R1800, R2400) have improved the banding
problems, but if equipped with piezogrphy ink, the lack of Dmax
should be still there.
What are your thoughts?
Re: [Digital BW] B9180 vs Piezography
2008-03-03 by Harold Jackson
I also print with an HP pigment based printer (Z3100) and wholeheartedly agree with you.  However, I also use an Epson R1800 and don't have the nozzle clogging problems that you described.  My thinking is that the 1290 is such old technology by today's standards that it just can't measure up in many ways.  The paper handling issue is clearly a relic of the fact that the older Epson printers were designed to handle much thinner, more flexible papers.  Also, these printers were designed for dye based inks and you are in essence "re-purposing " them when you use the Piezography inks in them.  So yes, your findings are in no way surprising.
2008-03-03 by Roger
What kind of Dmax difference are you seeing on matte papers?  I'm
surprised there's that big a difference among modern pigment blacks.
2008-03-04 by warinstephan
It's clearly noticeable by eyes.
I have no spectrophotometer, but after noticing it, I dug on the net
and found :
piezo black on HPR Dmax 1,58
B9180 on HPR: Dmax 1,75
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger"
