Epson Ultrasmooth Fine Art - PremierArt HotPress
2008-03-04 by the_des_bois
I am just wondering since Epson already uses PA HotPress 205gsm for
it's Scrapbook paper...
Is Ultrasmooth Fine Art made for Epson by PremierArt?
Is it safe to assume that the heavier PA HotPress 325gsm would behave
in a similar fashion than the more expensive Epson USFA?
Denis
Re: [Digital BW] Epson Ultrasmooth Fine Art - PremierArt HotPress
2008-03-04 by Josh Hackney
Denis,
Paul Roark might respond too, because I know he uses the 325gsm version of
the Premier Art Hotpress, but from my testing with QTR Create ICC, the
profiles from the Premier paper and Epson Ultrasmooth Fine Art are
practically identical.  They also look identical.  The absolutely no way I'd
be able to identify which is which if someone tested me.  I use them
interchangeable with my QTR Create ICC profiles.  I have used them both for
the past 2 years.
Compared to HPR and other brightened papers, it's very warm, but it's
similar to other OBA free papers such as Museum Etching.  It's great paper,
and both versions are double sided, which is nice, since I use the second
side of my mistakes for proofing.
The box for the Epson version has to be the nicest packaging of fine art
paper I've ever seen.  Inside the box, the paper is surrounded by 2 inches
of styrofoam to protect the edges/corners from being crushed in transit.
Very nice.  I think the Premier version is about 40% cheaper . . . and I
haven't had THAT many crushed corners with the Premier packaging!  The
Premier version is available in a lot more sizes too.  USFA isn't available
smaller than 13x19.
Josh
On Tue, Mar 4, 2008 at 2:14 PM, the_des_bois <thedesbois@...>
> Thanks,
> Denis
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY
> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Re: Epson Ultrasmooth Fine Art - PremierArt HotPress
2008-03-04 by pr_roark
Maybe better.  While it does not always seem to be the case, I
generally have obtained a better dmax with Premier Art 325.  For
example, comparing my QTR 1800 3MK profiles, you'll note the
linearization table has L 17.46 for UltraSmooth and L 16.02 for Premier
Art 325.
2008-03-05 by the_des_bois
Thanks Josh for sharing your personal experience with this paper.
Funny I was on the phone with someone from Premier Art (just after
posting) asking about printer settings and ICC for some color work.
Obviously they recommended custom profiles for the best results but
suggested Epson Ultrasmooth as a very good start point and told me
they where the ones selling the paper to Espon. I did some more
searches here and it has been mentioned in earlier (2005) posts here.
I guess Epson does not make much paper.
For the 205gsm, the VFA Espon profile works better and VFA paper
setting also. With USFA paper setting it overloads the paper. And the
Epson PA Scrapbook profile just does not print as nicely as with the
VFA profile. Again talking about color here.
Paul's curve for B/W 3MK with QTR are what I use for this paper.
Thanks again,
Denis
version of
way I'd
