ASTM Pigment Names and Numbers
2008-03-18 by Brian Corll
Does anyone know if the ASTM pigment names and numbers for Epson inks  are
published anywhere, or does anyone have this information ?
Brian Corll
http://www.briancorll.com
Re: ASTM Pigment Names and Numbers
2008-03-19 by pr_roark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Corll"
are
The numbers on the right at
http://www.paulroark.com/BW-Info/Color-pigments.jpg
<http://www.paulroark.com/BW-Info/Color-pigments.jpg>  may be what
you're looking for.  They appear to be fairly standard in the color
industry.  The magenta may be slightly different.
www.PaulRoark.com <http://www.PaulRoark.com>
RE: [Digital BW] Re: ASTM Pigment Names and Numbers
2008-03-19 by Brian Corll
Thanks, Paul. Interesting.having been a painter for 40 years I recognize all
of the pigment names. The red is quinacridone red, slight bluish, non-toxic,
and the most lightfast color in its range. The blue is phthalocyanine blue
(my favorite), possibly carcinogenic, and also complete permanent (in use
since 1936). The yellow is Hansa yellow,non-toxic, may fade in tints.  Just
what I expected.
Brian Corll
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of pr_roark
Sent: Tuesday, March 18, 2008 8:22 PM
Subject: [Digital BW] Re: ASTM Pigment Names and Numbers
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "Brian Corll"
are
> ... having been a painter for 40 years I recognize all
In a sense, inkjet printers are photographic water-color painters.
blue
use
> since 1936).
The cyan is very lightfast, but it is subject to UV and gas attack.
> what I expected.
There is a very interesting Dan Smith pigment that is directly opposite
carbon yellow in the color wheel and can make a single-pigment offset to
the carbon.  It's indanthrone blue.  I've actually used it in an inkjet
printer and fade tested it.  It's not quite up to cyan, but overall in
the same league as our M + C cooling methods.  And, it will not cause
the inkset to drift into green as it fades.  The fade path will be
straight back to carbon warm.
Some innovative ink company ought to persuade  Dan Smith or IS to do the
correct prep work needed to make this into a viable inkjet pigment for
B&W.  I've obviously decided not to take on that task myself.
Paul,
What do you mean by "correct prep work needed to make this into a viable
inkjet pigment" ?
Brian Corll
Sent: Tuesday, March 18, 2008 10:14 PM
blue
use
> since 1936).
> what I expected.
> this into a viable inkjet pigment" ?
The pigment particle sizes need to be correct, and I believe
dispersants are added at the ball grinding stage.  The water color
pigment I bought and used would not stay in suspension well enough to
be used for other than testing.  It also did not print as smoothly as
it should have.  So, I think more is needed than just putting water
color pigments into a good base and filtering it to eliminate the large
particles.
2008-03-19 by Greg
> Paul,
viable
> inkjet pigment" ?
Grinding to the proper size, suspending it in the proper base, and
concentrating it to the proper amount is really all it would take.
As a specialty ink it would not be a mass market seller, so the price
to have Image Specialists produce this would probably be very high.
What we now need is a DIY pigment grinder and filter, plus a good
mixer to make this a DIY project. Buy the base in the gallon sizes
and go. Still not exactly cheap, but possibly cheaper than having an
ink company make extremely short runs. Anything less than several 55
gallon drums is a short run for most of them.
Have you tried Sinopia or Kremer pigments ? Were the watercolor pigments dry
or already mixed with gum arabic ?
Brian Corll
Sent: Wednesday, March 19, 2008 10:49 AM
particles.
I only tried Daniel Smith's.
They were in the tubes with a medium that I'm quite sure included gum
arabic.
You might want to try the other brands like I mentioned. Cheaper than Daniel
Smith too. When it comes to art supplies, Daniel Smith is overpriced, IMHO.
Sinopia pigments are made in China and shipped from SF. Kremer pigments are
German and shipped from New York.
Brian Corll
Sent: Wednesday, March 19, 2008 1:39 PM
arabic.
