Carbon-6, 2200, & C88+
2008-03-22 by pr_roark
I've been experimenting with different ways to profile the C6 inkset in the 2200. The QTR rip appears to be just a bit better than the Epson driver, but they are so close I don't think even with a magnifier anyone will notice the difference. With the Epson driver the LK cross-over can cause problems with curves unless the curves converge evenly as they approach 100%. I've been using my Grand Canyon shot -- http://paulroark.com/Grand_Cyn.html <http://paulroark.com/Grand_Cyn.html> -- as the test print Even when the 21-step ramp looks perfect, most of the Photoshop curves I tried put artifacts in the sky. The artifacts look like haze waves and are caused by the slope of the ramp being un-even. So, it's a very tough image to print well. I'm quite sure the LK cross-over is what causes the problem, and having the color curves converge very evenly solved the problem. While partitioned curves made in Photoshop and embedded in an ICC with Create ICC-RGB make among the best prints, a very simple grayscale ICC is visually equal and essentially perfect. That is, I just print a 21-step test file with the driver at 2880 and Color Controls gamma 2.2. I read that 21-step file and make an ICC with Create-ICC (no curves). Then print the test print with that grayscale ICC, and the image is visually -- even with a magnifying hood -- as good as the best I've seen. So, easy works for me. 1440 will be visually OK for most, but upon very close inspection, I can see the difference between it and 2880. Since I'll actually be using the 2200 for my printing, I'll no doubt have a number of profiles for it with time. Next up is the C88+. Epson has them in stock, so I bought one for my daughter who is going away to college and will need a printer. While I'll set that up with a SuperJet (eBay) CIS and color for her, before that I'll see if Carbon-6 works for that printer. Paul www.PaulRoark.com <http://www.PaulRoark.com> [Non-text portions of this message have been removed]
