UT-FS: Y-position prints too dark...
2008-04-07 by Igor Wesdorp
Hello, I hope some expert is able and willing to help me with the problem I encountered, cause it drives me nuts and I can't go on with my work if I don't get it right. CONFIGURATION: Epson 1160 MIS UT-FS inkset (quadtone, monochrome) Windows XP PROBLEMS: Today, immediately after I refilled the carts, the ink in the Y-position printed far too dark. I could even see it in the printed nozzle check pattern. While it should be the lightest of the 4 inks, it prints even darker then the ink in the M-position. And: there are strange dark and light lines to the left margin of a printed swatch (which is not banding), not once but every time. (See the picture at http://members.chello.nl/iwesdorp/problem/yellow.jpg) First I thought I had used the wrong ink for filling the Y in the cart, but that was not the case. And I tried all kinds of things: making lots of purge/flush prints, resetting the printer, taking out the carts etc. But to no avail. Does anyone know a remedy? Thank you so much. Igor Amsterdam
