Need advice on selecting a printer
2008-04-17 by niteowl1004
Hello all! I am just starting to move into the digital age, have been a traditonal "wet" printer for many years. I am looking for a starter printer to get working with, but with 13" width.I have been debating on an epson 1280, or the new 1400. Any suggestions would be great! Scott
2008-04-18 by Clayton Jones
Hello Scott, >I am just starting to move into the digital age, have been a >traditonal "wet" printer for many years. I am looking for a starter >printer to get working with, but with 13" width.I have been debating >on an epson 1280, or the new 1400. Any suggestions would be great! Welcome to the forum. It's hard to make a recommendation, we need a bit more information. Does "Starter" mean inexpensive or easy to use (or both)? Are you technically inclined or not? If ease of use is important then the Epson 2400 is great, but it costs more. If cost is the issue then a 1280/1400/1800 may do the job but they will require more time/effort/hassle (refilling carts or using a CIS, using a RIP, using curves/profiles, etc) than the 2400. Also, what kind of paper you want to use (matte, glossy, fiber gloss) could affect the choice. The 2400's K3 inks are great on the new fiber gloss papers. If money is not the biggest issue then the 2400 is a great way to go. It can do great BW out of the box, and you can move into using a RIP, experimenting with different inks, CIS, using a densitometer, etc. later as your own interest/inclination/desire leads you. Plus, if you like the gloss papers, the K3 inks are among the best (if not the best) re low bronzing and gloss differential. Other than higher cost, it is IMO the best route for a beginner to get productive right away with very little hassle and frustration. Article #9 at the link below outlines a simple and effective workflow for the 2400. It will give a good idea of what it's like to use this printer. If the technical stuff and learning curve don't bother you and highest archival level is of top importance, then the 1800 with Paul Roark's new all carbon methods may be the best route. http://www.paulroark.com So you can see there's no simple answer. All of these things need to be considered. I hope this helps. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm I-Trak 2.1 http://www.cjcom.net/itrak.htm
2008-04-18 by joe.gagliardo
Scott, I am you several weeks ago!! I too am/was a "wet" printer. I purchased a Nikon D300 and decided to move into the digital world. I initially purchased an Epson 1400 and spent a great deal of time money and effort in paper, inks ect....yeilding in frustration. Don't misunderstand me the 1400 is a fine printer, but if you are used to printing blank and white on glossy paper this is not the best way to go. I too orginially debated on 1400 vs 2400. Like I said, after wasting a great deal of money and time went with the 2400. This in my opinion was the way to go. The Advanced Black and White portion of the printer driver is excellent. With a calibrated montior I had black and white prints with no color cast on glossy paper that look great "out of the box"!!!! It took me about 1 hour to unpack and print my first great looking print. I only wish I had followed my original instinct and purchased the 2400 out of the gate. Yes, it is more expensive, but I would have spent less had I gone that way to begin with. Just my two cents!! Good luck in whatever you decide! :) Joe --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "niteowl1004" <cohen.scott@...> wrote: > > Hello all! > > I am just starting to move into the digital age, have been a > traditonal "wet" printer for many years. I am looking for a starter > printer to get working with, but with 13" width.I have been debating
> on an epson 1280, or the new 1400. Any suggestions would be great! > > Scott >
2008-04-18 by pr_roark
> I initially purchased an Epson 1400 ... By the way, I'll soon have a 1400 and will see if the UT-RC inks, as well as some others, work on it. I expect we'll see a setup similar to the 260 setup described here: http://www.paulroark.com/BW-Info/R260.htm The MIS UT-RC inkset is matte and glossy compatible, depending on the black ink installed. I think QTR will allow a reasonably good Black Only from the 1400 also. But, no quaratees at this point. Paul www.PaulRoark.com
