Have printer, where to go now?
2008-04-28 by niteowl1004
Many thanks to Paul, Clayton, and Joe on all the advice for selecting a printer. Unfortunately, I couldn't spring for a 2400, and I wanted to be able to go large format, so I opted for pain and got a 1400, which has the 6 inkset. I got QTR, and they have a setting for the 1400 BO. Started to print, made some curves, but I think some kind of education would be good. I do a lot of portraits and still life shots, and like the matte or satin type finishes. I shoot with a Hassleblad and scan with a epson flat bed. So here are the questions.... 1. To get high quality shots at 13 x 19 what resolution should I be scanning at. My scanner can go to 9600dpi, and the files are HUGE!I end up with 500 and 600 mb files. I can't see much difference between the files when i print lower res files, say 3600dpi 2. While I am getting ok results, I am not close enough to what I could produce in my wet darkroom. Should I go to the quadtones to get that kind of result? 3. Are there quadtone curves for the 1400? That use multiple carts? 4. I ordered a set of carts for the printer, I had no idea how much ink I could go through in a couple of days of goofing around. When I get them, I can go to other black inks, any reccomendatons? 5. Any books, or other resources that I should look at? Thanks to all, Scott
