Great info - thanks! Does it have to be the I1 spectro or can I use
Print Fix Pro?
SteveB
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Weaver"
<garww@...> wrote:
> Or, you can just eyeball the print : )
> gar
> *********** REPLY SEPARATOR ***********
> On 5/12/08 at 7:52 PM slcphoto73 wrote:
> >OK, with a lot of help (see discussion in the EpsonWideFormat
group, I
> >came up with the following For Dummies summary:
> > Creating and Using Your Own Grayscale Profiles (Windows)
> >Based on information gleaned from Eric Chan, Giorgio Trucco,
Stephen
> >Best, and Walker Blackwell.
> >1. Acquire the necessary tools
> >- A spectrophotometer (I think it has to be the I1.)
> >- QuadTone RIP (QTR includes a Step 51 Gray chart which you print
and
> >measure and the software that creates the profile. On Windows, go
to
> >http://software.sbillard.org/QTRgui.htm )
> >- MeasureTool from GretagMacbeth (Download the GretagMacbeth
> >ProfileMaker demo version and install the MeasureTool. MeasureTool
> >will run without a dongle, so you don't need to actually buy the
> >expensive ProfileMaker to use it.)
> >2. Make the test print
> >- Open QTR\eye-one\Step-51-gray.tif into Photoshop, telling
Photoshop
> >"don't color manage"
> >- Print it onto the paper for which you are making the profile
> > - In the Photoshop print dialog box, select "no color
management"
> > - In the print driver dialog box, specify Advanced Black and
> >White with whatever other settings you want to use for this paper.
> >Giorgio Trucco recommends "
using the Dark setting for better
linearity."
> > - Let the print dry
> >3. Use MeasureTool and your spectrophotometer to read the target
> >- Open MeasureTool
> >- Select "Configuring"
> > - Specify "reflection" (for measuring paper) and leave
Spectral
> >toggles unchecked (this exports as LAB values)
> > - Specify your measurement device. I found I had to select
it
> >even if it already appeared in the dropdown window.
> >- Select "Measuring"
> > - Select the chart you printed (QTR 51 Gray) (I think I
remember
> >that I had to copy QTR-Gray-51.txt from the QTR program files
folder
> >into C:\Program Files\GretagMacbeth\ProfileMaker Professional
> >5.0.8\Reference Files\Printer)
> > - Follow the instructions to measure the chart
> >- Select File/SaveAs to save the result as .txt
> >4. Turn the .txt file into a profile
> >- Copy the .txt file to QTR\eye-one (WARNING: on Windows Vista I
> >found I had to copy QTR_Create_ICC.exe to a regular directory, one
> >that is not UAC controlled, and put the .txt file in the same
directory)
> >- Drag/drop the .txt file into QTR_Create_ICC.exe (If no .icc file
> >appears check the out.txt file (also created by
QTR_Create_ICC.exe).
> >There may be an explanatory warning message at the bottom.)
> >- Put the new profile into where your color profiles are kept. On
> >Windows/Vista, that is C:\Windows\System32\spool\drivers\color
> >5. To use the gray profile to soft proof
> >- Works just like a color profile
> >- Rendering intent must be Perceptual
> >- Do use black point compensation
> >6. To use the gray profile to print
> >- Make sure your image is in mode RGB convert it if necessary
> >- In Photoshop print dialog
> > - Let Photoshop determine colors
> > - Select the QTR profile
> > - Select "perceptual" rendering intent because QTR only
> >supports perceptual
> > - Do check black point compensation
> >- In the printer driver dialog set the driver to the same
settings as
> >used to print the QTR 51 Gray chart.
> >Hope this is correct and helpful. Any improvements/suggestions are
> >welcome; eventually this file should be posted to the Web somewhere
> >for others to find (I don't have a Web site).
> > - susan
> >Please visit the Group Homepage to check the Files, and other
resources as
> >they are often being updated.
> >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> >If you wish to receive no emails or just a daily digest, or you
wish to
> >unsubscribe, please edit your Membership preferences by visiting
this same
> >page.
> >Please follow these basic guidelines:
> >- As threads develop, trim off excess portions of earlier messages
to keep
> >them short.
> >- Good manners are required at all time. No personal attacks or
flames.
> >Hostile, aggressive or argumentative users may be removed from the
> >membership without notice.
> >- Keep your posts and threads related to the group topic of
digital B&W
> >printing. Users who persistently make off-topic posts may be
removed from
> >the membership.
> >- By posting on this forum you agree to abide by the group rules
and
> >guidelines, and to abide by the actions and decisions of the group
Owner
> >and Moderators. See "Group Topic, Rules and Guidelines" in the
Files
> >section:
> >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
> >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
PRINT
> >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO
> >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS
OF
> >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
THE
> >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE
BEEN
> >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i)
THE USE
> >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR
DATA; (iii)
> >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT
> >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE
> >PRINT YAHOO GROUP.
> >Yahoo! Groups Links
