We need to know a little more. How much do you want to spend, and how
big do you want to print? In addition, what is the main types of film
that you want to scan? Slow, fine-grained film, or fast, high speed
film? Do you need it to be to do batch scans? Do you want to wet-mount
the film?
General suggestions:
1. Epson V700.
2. Nikon Coolscan V
3. Microtek M1
4. Nikon Coolscan 5000.
5. Nikon Coolscan 9000.
6. Used pre-press flat-bed, like a Screen Cezanne, Creo Eversmart...
7. Used low end drum scanner, such as a Howtek 4500.
8. New Creo IQ Smart 3.
9. New Aztek Premier drum scanner.
That list generally goes from cheapest/lowest quality to really
expensive/highest quality, although it depends on the film, and some of
the ordering is a little controversial. (For example, I expect that 2.
give better results than 3., but 3. is more expensive.) The Nikon film
scanners do a great job with fine-grained film, but they don't do that
well with larger grained film. You can wetscan with an appropriate
holder and the 9000, but probably not with the V or 5000. Wet scanning
does minimize scanner grain growth a bit, although the results are
highly film dependent.With the V, and FH-3 strip holder gives better
edge to edge sharpness than the standard motorized strip holder. With
really grainy film, such as Kodak High Speed Infrared, I've found that
the flatbeds do a better job. (In my case a Canon 9950F flatbed blows
away my Nikon V film scanner, whereas with fine-grained film the results
are reversed.)
The only reasons to go past step 4 if you need to do 120mm film, you
really, really want to wet mount 35mm with a film scanner, you need to
make really big prints, or you have a lot of really dense film, such as
under-exposed Velvia. 6-10 do give better results, but the costs, size,
and general trouble increase almost exponentially.
Personally, I have a Canon 9950F flatbed, a Nikon V film scanner, and a
Screen Cezanne pre-press flatbed.
