Epson 740 - B&W conversion possible?
2008-05-30 by fabozzism
Hello there everybody,
  I have this old printer that I would like to convert to B&W.
I visited shops and saw many cheap printers, but my 740 is almost
unused and I'm not searching for "the quality #1 in the world". I
rarely have to print my photo in B&W, but I'm not a pro, then gotta
save money first...
What software could I buy to use "1 black + 3 gray" with this printer?
Do you see any possible problem with inks compatibility?
Many thanks for your answers!
Stefano
Re: Epson 740 - B&W conversion possible?
2008-05-31 by pr_roark
> unused ...
Looking at http://inksupply.com/epsonclean.cfm it appears the 740 uses
1160 type carts.  The 1160 was a very popular B&W printer.  See
http://www.inksupply.com/ut_kits.cfm?action=find for a list of some B&W
options that may work well with the printer.
>... I rarely have to print my photo in B&W,
Using a printer infrequently has correlated with nozzle problems.
My experience has been that the matte paper only inks like the Eboni-6
and Carbon-6 are more reliable in infrequently used printers.
Assuming the 740 is a 4-ink printer like the 1160, I'd look at the
solution I made for the C88.
See http://www.paulroark.com/BW-Info/C88-C13-5.pdf
> ... gotta save money first...
Carbon-6 is the best per dollar.
You may not need any other than the Epson driver.
Clean the parking pad well.  Eboni (MIS MK) and dye are no compatible.
I use a syringe with cleaning fluid in it for this.  Even water would
probably work.
Good luck.
