Profile(?) Problem
2008-08-07 by Les Berkley
Hello all! I am slowly getting into 'more serious' black-and-white printing (since I sold some prints). I outsource larger sizes, but I print most of the work on my Epson R800. I recently began 'toning' my files with PS adjustment layers, and now with Nik SilverEfex (which I like a good deal). Here's my problem. My monitor is profiled with Spyder2 Pro. I believe the profile to be very good. Known files look correct on screen, and most importantly, a greyscale step wedge looks neutral across the range from white to black. Color images print very accurately on the R800, using the latest manufacturer's profiles. Neutral b/w images (with equal RGB values throughout) print neutral to very, very, very slightly cool. (In wet darkroom terms, about CC 02 at worst.) BUT the 'toned' files print too cool, and skewed at times toward a rather nasty purplish tone in the mids. This tone is most visible under my D50 Ottlite, but also shows up in daylight/incandescent as well. (I guess this is 'metamerism'.) I note that, looking at the RGB numbers in the file, the on-screen display appears correct. So what can I do to get a better screen-to-print match? I don't have the budget for a spectro, and I'm a bit leery of profiling with a scanner (but would try it). I am also considering converting a 1280 I own for strictly b/w work using the MIS carts. This would undoubtedly get me consistent reults--and clogs--but it would remove the 'toning' I am doing. TIA, Les
