Crazy variation of C-6 for the R1800
2008-08-10 by the_des_bois
Hello, I just wanted to report my home brewing experiences based on Paul Roark's "Carbon-6" B&W Inkset. I mixed my C-6 base using distilled water and Glycerol USP both bought at a local pharmacy. Initial tests without PhotoFlo in the mix showed a lot of banding for the 2%, 4%, 8% and 16% dilutions. Having no Photo-Flo, I tried a 50-50 mix of Ecover Rinse Aid and Nature Clean Rinse Agent bought at local grocery store. I mixed the two in the hope the combination of different surfactants would create a working synergy. Banding is now gone. Zero. Nothing. Even under a magnifying glass. Knowing I could not print using Epson's driver because we do not know what the driver does with the Blue and Red ink channels, I played a lot with QTR. Having no spectro, I looked at existing curves. I settled on the 9880-UC warm curve that uses one pure MK, one LK and one LLK dilution. I adapted that curve so that my R1800 would use one 100% density pure Eboni channel, three 16% dilution LK channels and two 4% dilution LLK channels. I kept two free channels so I can always use the simple 3MK approach if I want a BO print. I used more than one channel for the LK and LLK in the hope of minimizing possible future banding. I also made the LK and LLK curves have slightly different slopes by changing the channels ink limit by + or - 4% to create more smoothness in the mids and highs. I am happy to report that, even without relinearizing, the prints show smother gradients on the sphere test gradient print than I used to get with K7 using the right curve and paper. Amazing. And so much smoother than the 3MK! It prints a lot warmer than 3MK in the light midtones and on Premierart BW 205 creates a very nice splittone effect. How stable this homemade brew will be I do not know. Will it kill my R1800? I don't care as the 1400 is as good or better and dirt cheap. So I can now print either a 3MK BO that has this special look for the highlights and sometimes very appealing "grain", or print warmer utrasmooth splittones. I also like the fact that this "system" only requires pure Eboni ink bought from Inksupply.com and that all the rest I can find at the pharmacy or grocery store. :-) I know I am not very good at describing this process but I wanted to share anyways. Denis Bouchard
