QTR+UT7+2200
QTR+UT7+2200
2008-08-13 by eyewall
Hello,
I have been printing on an Epson 2200 with the UC inks and QTR for a
while, but I have decided that now is a good time to try dedicated black \
inks. I don't really like continuous ink systems, so I have bought a
set of UT7 inks from MIS (no pk) for the 2200. I print with Hahnemuhle Ph\
oto Rag and Museo Portfolio Rag.
Can anyone point to an article/site/etc that can give me some info
about how to use the UT7 inks (Roark workflow) with QTR/
Thanks
Re: QTR+UT7+2200
2008-08-13 by pr_roark
Although this is probably not what you had I mind, an alternative worth
considering is using the Photoshop curves that are linked to my general
2200 UT7 write-up at
http://www.paulroark.com/BW-Info/UT-2200-Readme.htm
and embedding them in ICCs made with QTR's Create ICC-RGB. See
http://www.paulroark.com/BW-Info/Embedding_Photoshop_Curves_in_ICCs.pdf
for information on making these ICCs.
While a spectro is ideal for this, one can use a flatbed scanner.  See
http://www.paulroark.com/BW-Info/Making_B-W_ICCs-GrayCard.pdf
With these ICCs the workflow is "color managed" with respect to
relative densities (that is, the monitor should match the print), the
system can be linearized to account for variable, and new papers can be
profiled fairly easily.  (There is usually a profile that gives tones
that are close, so all that is needed is re-linearization.)
Good luck with the system.
Re: QTR+UT7+2200
Thanks. I'll see what I can do.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> Paul
> www.PaulRoark.com
