wireless printing
wireless printing
2008-08-20 by Igor Wesdorp
Hello,
About wireless printing:
I've just moved and the 3800 I ordered will have to stand in the other
corner of my room, away from my pc, so not having to use a cable sure
looks nice. But does it work?
I would like to know:
- Does it make a difference if you print wireless? (apart from not
 having to use a cable)
- Is it reliable?
- Is the print quality the same?
- Is it slower?
- What kind of gear will I need?
Thanks!
I g o r
Amersfoort
Holland
Re: wireless printing
2008-08-20 by photo_vinc
I have a setup here where I use a router connected to the 3800 (a
bridge would be the right solution, I am not sure if this works with
every router).
I did not found any difference.
> - Is it reliable?
Till now (about 500 pages, mostly A3+) I never had a problem, distance
here from one corner to the next is about 4 meter)
Absolutely!
> - Is it slower?
I did not found any difference, I however also did not perform
measurements.
Try to get a Bridge and a wlan card for the PC. (I use separate
network for printer, I did want to keep it separate from internet)
Vinc
http://www.photo-vinc.com <http://www.photo-vinc.com>
2008-08-25 by Igor Wesdorp
Thank you, Vinc.
I will consider it.
I do have a Fritzbox WLAN modem (for internet) connected to my pc. Can
that be of any use for wireless printing?
Igor
2008-08-26 by photo_vinc
most probably yes.. however as said before I would recommend to setup a
separate WLAN for the printer to keep the printer as far as possible
from the internet.
Vinc
