UT-14 and color ink question
2008-09-13 by buck caberney
Hello.  I have an Epson 1400 printer in which I plan to use the UT-14
inkset from inksupply.com.  My question is, can I switch between the
cartridges of UT-14 and cartridges of color pigment ink in the same
printer without causing problems?  Do I need to clean thje printheads
when switching?  Thanks in advance for any info/ advice!
yes
2008-09-14 by Tony
<brianbarger01@...> wrote:
Do I need to clean thje printheads  when switching?
I have the same set up and yes you definitely need to do a head
cleaning until all color is purged or at least one head cleaning which
will happen automatically then do some large color purge prints to
check that all color is purged.
You do not have to do a cleaning cartridge purge filled with cleaner or
base fluid.
I wouldn't swap out much or you will go thru tons of ink.
I've got 1400 with dedicated UT14 CIS and another with color CIS. I'm
contemplating putting pigment Ultrachrome K3 (or rather K4 equivalent
third party ink) in my third 1400 but not sure how well it will profile.
