Canon 5D Mark II
2008-09-19 by pr_roark
The camera I bought the 90 TS lens for: http://www.photokina-show.com/0584/canon/digitalslrcamera/eos-5d-mark-2/ Paul www.PaulRoark.com
2008-09-19 by Ernst Dinkla
pr_roark wrote: > The camera I bought the 90 TS lens for: > > http://www.photokina-show.com/0584/canon/digitalslrcamera/eos-5d-mark-2/ If it has the dynamic range of a Fuji S5 then there isn't much left to stay with film. Although an MF folder camera fits better in a coat pocket. The Fuji GF670 demo is on the Photokina too. -- Met vriendelijke groeten,Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2008-09-19 by Dana H. Myers
Ernst Dinkla wrote: > > > pr_roark wrote: > > The camera I bought the 90 TS lens for: > > > > > http://www.photokina-show.com/0584/canon/digitalslrcamera/eos-5d-mark-2/ > <http://www.photokina-show.com/0584/canon/digitalslrcamera/eos-5d-mark-2/> > > If it has the dynamic range of a Fuji S5 then there isn't > much left to stay with film. > Although an MF folder camera fits better in a coat pocket. > The Fuji GF670 demo is on the Photokina too. There's something to be said for HDR scans of mainstream MF negative film... Dana
Dana H. Myers wrote: > Ernst Dinkla wrote: >> >> pr_roark wrote: >> > The camera I bought the 90 TS lens for: >> > >> > >> http://www.photokina-show.com/0584/canon/digitalslrcamera/eos-5d-mark-2/ >> <http://www.photokina-show.com/0584/canon/digitalslrcamera/eos-5d-mark-2/> >> >> If it has the dynamic range of a Fuji S5 then there isn't >> much left to stay with film. >> Although an MF folder camera fits better in a coat pocket. >> The Fuji GF670 demo is on the Photokina too. > > There's something to be said for HDR scans of mainstream > MF negative film... > > Dana Or for example multisampling/long exposure with a Nikon 8000 on wet mounted color negative film like I do. Similar artefacts seen in digital HDR can show though. In this case higher noise in the highlights for color negative. Exposure bracketing on a DSLR isn't bad either if the subject allows it, goes faster between shots than on an analogue MF camera. -- Met vriendelijke groeten, Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2008-09-19 by Roger
> Or for example multisampling/long exposure with a Nikon 8000 > on wet mounted color negative film like I do. Similar > artefacts seen in digital HDR can show though. In this case > higher noise in the highlights for color negative. > > Exposure bracketing on a DSLR isn't bad either if the > subject allows it, goes faster between shots than on an > analogue MF camera. I'm surprised you see a reduction in scanner noise in *color* negative highlights using multiexposure scans. I usually find that if I set the overall scanner exposure correctly the entire dynamic range of the color negative is well within the scanner's range and nowhere near the scanner's Dmax. Some B&W negs and slides do benefit from this technique. I use Photomatix's combine exposures feature to blend bracketed scans (and DSLR shots). I like it better than HDR and tonemapping.
Roger wrote: >> Or for example multisampling/long exposure with a Nikon 8000 >> on wet mounted color negative film like I do. Similar >> artefacts seen in digital HDR can show though. In this case >> higher noise in the highlights for color negative. >> >> Exposure bracketing on a DSLR isn't bad either if the >> subject allows it, goes faster between shots than on an >> analogue MF camera. > > I'm surprised you see a reduction in scanner noise in *color* negative > highlights using multiexposure scans. I usually find that if I set > the overall scanner exposure correctly the entire dynamic range of the > color negative is well within the scanner's range and nowhere near the > scanner's Dmax. Some B&W negs and slides do benefit from this > technique. I use Photomatix's combine exposures feature to blend > bracketed scans (and DSLR shots). I like it better than HDR and > tonemapping. > > It isn't the dynamic range or Dmax not captured by the scanner but its problem with reproducing the tone values accurately from the compressed range of the color negative that can be solved with multisampling and spreading the result on 16 bit. The noise in the highlights is what I still see though so it just works not as good in dense parts of the color negative. The long exposure is what I use for B&W negative and there I see the same (not similar) artefacts in the shadows observed in digital HDR. Nothing special just Vuescan's tools. Few times I scan slides. I agree that it could have been written more clearly. -- Met vriendelijke groeten, Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2008-09-19 by Bruce Watson
Ernst Dinkla wrote: > Roger wrote: > >>> Or for example multisampling/long exposure with a Nikon 8000 >>> on wet mounted color negative film like I do. Similar >>> artefacts seen in digital HDR can show though. In this case >>> higher noise in the highlights for color negative. >>> >>> Exposure bracketing on a DSLR isn't bad either if the >>> subject allows it, goes faster between shots than on an >>> analogue MF camera. >>> >> I'm surprised you see a reduction in scanner noise in *color* negative highlights using multiexposure scans. I usually find that if I set the overall scanner exposure correctly the entire dynamic range of the color negative is well within the scanner's range and nowhere near the scanner's Dmax. Some B&W negs and slides do benefit from this technique. I use Photomatix's combine exposures feature to blend bracketed scans (and DSLR shots). I like it better than HDR and tonemapping. >> > > It isn't the dynamic range or Dmax not captured by the > scanner but its problem with reproducing the tone values > accurately from the compressed range of the color negative > that can be solved with multisampling and spreading the > result on 16 bit. The noise in the highlights is what I > still see though so it just works not as good in dense parts > of the color negative. The long exposure is what I use for > B&W negative and there I see the same (not similar) > artefacts in the shadows observed in digital HDR. Nothing > special just Vuescan's tools. Few times I scan slides. I > agree that it could have been written more clearly. > It's not a failure of color negative materials. People routinely blame poor scanner performance on color negative tonal compression. Yet, I routinely scan color negatives on my drum scanner with excellent results. I never experience of these so-called compression problems. And if any scanner / software / operator can get excellent results from color negative materials, the fault is not with the film, but elsewhere. CCD scanners, OTOH, may well be subject to this "compression" failing. I have too little experience to venture forth an opinion on CCD scanner / software performance. All that said, the nature of film is that graininess is not a constant. It varies directly with density. Low density regions of the film show very low graininess, while high density regions can show orders of magnitude higher graininess. With a tranny, greatest film density is in the print's shadows where the graininess is hardest to see. With negatives, greatest film density is in the print's highlights were it's much easier to see. This makes negative film "seem" grainier (noisier) when in fact modern negative materials nearly always have lower graininess indices then their same ISO tranny counterparts. Since this is a B&W group, I should add that the same thing applies to B&W negative films; that graininess is directly related to density. But there's an added twist. Callier Effect is also directly related to density. The effect is that higher density regions of the film cause more light scatter (Callier Effect) which in turn lowers the local contrast for that region of the film. The result in the print is highlight compression, and again many people blame this on film shouldering. Both scanners (CCD and PMT) and darkroom enlargers experience this, and it's one reason why optimizing B&W film processing for scanning means decreasing development to decrease Dmax which in turn decreases the amount of metallic silver in the dense regions of the film, which in turn reduces both graininess and Callier Effect. -- Bruce Watson
2008-09-19 by Gary Weaver
I really like folders !! If they can hold a film flat, it's the best thing since sliced bread. gar *********** REPLY SEPARATOR ***********
On 9/19/2008 at 9:11 AM Ernst Dinkla wrote: >pr_roark wrote: >> The camera I bought the 90 TS lens for: >> >> http://www.photokina-show.com/0584/canon/digitalslrcamera/eos-5d-mark-2/ > >If it has the dynamic range of a Fuji S5 then there isn't >much left to stay with film. >Although an MF folder camera fits better in a coat pocket. >The Fuji GF670 demo is on the Photokina too. > > >-- >Met vriendelijke groeten,Ernst > > >| Dinkla Grafische Techniek | >| www.pigment-print.com | >| ( unvollendet ) | > >------------------------------------ > >Please visit the Group Homepage to check the Files, and other resources as >they are often being updated. > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > >If you wish to receive no emails or just a daily digest, or you wish to >unsubscribe, please edit your Membership preferences by visiting this same >page. > >Please follow these basic guidelines: >- As threads develop, trim off excess portions of earlier messages to keep >them short. >- Good manners are required at all time. No personal attacks or flames. >Hostile, aggressive or argumentative users may be removed from the >membership without notice. >- Keep your posts and threads related to the group topic of digital B&W >printing. Users who persistently make off-topic posts may be removed from >the membership. >- By posting on this forum you agree to abide by the group rules and >guidelines, and to abide by the actions and decisions of the group Owner >and Moderators. See Group Topic, Rules and Guidelines in the Files >section: >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND >MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE >OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE >PRINT YAHOO GROUP. >Yahoo! Groups Links > > >
2008-09-19 by Roger
The long exposure is what I use for > B&W negative and there I see the same (not similar) > artefacts in the shadows observed in digital HDR. Nothing > special just Vuescan's tools Just one comment- the artifacts you are seeing may relate to flaws with Vuescan rather than the scanner or negative material. I strongly caution *against* using Vuescan's long-exposure pass (it has a new name but does not seem improved) which has alignment issues, can introduce halos and doesn't really reduce noise. The free version of Photomatix will blend two images and not apply a watermark. The pay versions give you more options. I highly recommend manually scanning (crop set to maximum, focus locked) exposing for the highlights and shadows and blending manually or with a program like Photomatix. I've also heard good things about Enfuse. This is a comparison I did a while ago: http://www.jingai.com/vuescan2/long%20exposure%20comparison.html The Photomatix blends are a bit mushy as I have since discovered I need to lock focus between first and second scans.
Roger wrote: > > The Photomatix blends are a bit mushy as I have since discovered I > need to lock focus between first and second scans. > > It is not just focus shift but there can be some shift of the film frame too between scans. That's what makes the difference between multisampling and multiscan in detail loss. -- Met vriendelijke groeten, Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
2008-09-19 by Roger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <edinkla@...> wrote: > > Roger wrote: > > > > > The Photomatix blends are a bit mushy as I have since discovered I > > need to lock focus between first and second scans. > > > It is not just focus shift but there can be some shift of > the film frame too between scans. That's what makes the > difference between multisampling and multiscan in detail loss. Yes, that's very true and easy to see (lay one scan over the other in Photoshop, pin register and lower opacity and it's clear they aren't quite lined up). My scanner does not do single pass multisampling and Vuescan's multipass multisampling and multiple exposure both have some alignment issues (among other problems.) Focus shift just makes things worse. Photomatix is fairly sophisticated when it comes to alignment (it's quite usable for "high speed HDR"- combining three bracketed handheld shots) and I find it deals with my scan alignment issues well enough, too. Worth a try to compare with your current workflow. If you're using a Coolscan with Vuescan also google Erik Krauss' "super advanced workflow" for a way to use analog gain to remove the C41 mask. Roger
