Photozone lens tests
2008-10-06 by pr_roark
A week or so ago we were discussing the various published tests and
how well (or not) they seemed to predict the performance of lenses or
agree with our own evaluations.
Using my Canon 8 mp Rebel, I tested a number of lenses I had that
were also tested by some magazines (Popular Photo in particular),
Photodo, and Photozone.  In comparing the results of my tests, which
use standard resolution charts as well as printed pages with assorted
print sizes and shapes, I must say the only tests that seem to
correlate well are the Photozone tests.
See http://photozone.de/
In fact, their tests, which use a similar digital camera, give almost
identical relative results.  This is probably becuase our test
routines are similar.  On the other hand, the Photodo tests, which I
used to think were about the best with respect to film cameras, have
a much lower correlation with what I see with the Rebel.  I suspect
part of the difference is the distinction between digital and film
cameras.
At any rate, I'm impressed with Photozone, although I hope they start
testing on full frame Canons also.
Re: [Digital BW] Photozone lens tests
2008-10-06 by Ernst Dinkla
Part of their problem is that they like to keep correlation
between all the lens test results so the relative old Canon
350D is still used, even for the latest lenses.
So FF but then with a pixel density that is the same to the
pixel density of the Canon 350D = 3.1ML/CM2 and the 5D MII
is  on 2.4 right now so we have to wait another year. Pixel
density isn't telling all as the pixel wells grow in size
and quality per generation even with the same pixel density.
DPreview faces the same problem: Andy Westlake's comment on
that issue somewhere in the middle of this page:
http://forums.dpreview.com/forums/readflat.asp?forum=1000&thread=28994243&page=2
ColorFoto has less compatibility between their lens test
results but tested more lenses on different sensors
including the most recent ones. They also lay more emphasis
on low contrast resolution in their latest test methods so
you have to check the test number next to the results:
Testverfahren 1.3-1.4-1.5.
Met vriendelijke groeten,  Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Re: Photozone lens tests
Ernst Dinkla wrote:
> > I hope they start
> 350D is still used, even for the latest lenses. ...
I would think that consistency would be most important for lens
tests.  So, using the same camera body -- even if old -- makes a lot
of sense.  The question then is whether the tests remain relevant for
the newer, better cameras.
As the cameras get better, I'd think we'd see the differences among
lenses magnified, but I wonder if the relative performance changes
much.  The Photozone tests, as well as my own using the 8 mp Rebel,
can see some of the results of diffraction limits in the center from
f5.6 to f8 (and more as we go to smaller f-stops).  So, even with
older camera designs we're seeing some changes (for example, f5.6 to
8 central sharpness) that are probably not going to be relevant to
actual shooting.  I don't hear many photographers complain of f8
diffraction being a serious limit.
As a practical matter, the lenses I was looking at are all very good
in the center at f5.6 - 11.
The edges and larger larger apertures are where the action is, and
there the image quality can look bad even with the older cameras.
I'd guess it's just going to be that much more worse compared to the
central image at f8 with the newer cameras.
On the other hand, I wonder if some of the color fringing at the
edges is due to sensor design as well as lens aberrations.  I don't
recall the color fringing being such a big deal with film.  The Canon
90 TS is the only lens I have that doesn't show that annoying defect
on both the Photozone tests and mine.  If fringing -- particularly
with wide angle lenses -- is, in part, a camera defect, they we might
have some changes that alter relative lens performance.
Re: [Digital BW] Re: Photozone lens tests
And I thought for some time that as color fringing can be
removed with software the lens designers compromise it more
in order to get other specs in line. Tokina for example in
its recent designs as tested by Photozone. An interesting
comment in the conclusion of DPreviews test report of the
Fuji S100FS:
"There is a cloud on the horizon, though, and its a cloud
with oddly-colored edges. Chromatic aberration (CA) is a
major problem at the focal lengths that are likely to be
most used. The effect is so pronounced at times that it is
visible even in small prints. The frustrating thing is that
CA can be removed automatically - we've seen it done in
other long-zoom cameras, so know it's possible,
economically. It can also be manually removed from RAW files
but the supplied FinePix Studio software doesn't provide the
tools to do, so again you're pushed towards using
third-party software that don't do the images justice."
If reviewers accept that approach then it is likely to
become the standard.
|             ( unvollendet )            |
Ernst Dinkla wrote:
> > edges is due to sensor design as well as lens aberrations. ...
> ... I thought for some time that as color fringing can be
> in order to get other specs in line. ...
My experience with B&W is that the color fringing manifests itself as
softenss on the affected edges, and the software "fixes" I've tried in
the Raw converters do not improve B&W sharpness.
I'd prefer better lenses (or sensors if they contribute) to a software
fix.
2008-10-07 by Peter Marquis-Kyle
> in the Raw converters do not improve B&W sharpness.
Paul, you might be interested to try the software corrections in PTLens,
which include color fringing (called chromatic aberration in PTLens).
See http://epaperpress.com/ptlens/ (free demo available).
Peter Marquis-Kyle
2008-10-07 by Ernst Dinkla
> fix.
Right, it was only to sketch that it may be more difficult
to get that quality in lenses when this fix is widely accepted.
|             ( unvollendet )            |
2008-12-27 by pr_roark
(Slightly OT)
I'd previously mentioned that the Photozone <http://photozone.de/> lens
tests seemed to correlate well with what I saw on my 1.6 x digital
camera.  But Photozone lacked full frame tests.
I've now found a site that has taken the Photozone types of tests to
full frame.  See http://slrlensreview.com/
This, plus, of course, the old Photodo
<http://www.photodo.com/products.html> tests may help us find glass
that is worthy of the latest sensors.
